WIW-4wd parts,2wd parts,gears,emblems,bucket seats,consoles,etc
Looking to clean out some extra parts and need to know the worth of it all so any opinions appreciated...
All the emblems are a pair 1) 4 Wheel Drive emblems-need painted 2) 8 350 Emlems-need painted for best results 3) Custom/10 emblems 4) Metal interior door panels w/out arm rest holes-One small bolt hole enlarged when removing 5) 5 lug rear axle shafts 6) 71-72 12 bolt axle housing and cover 7) 3:07 Ring,pinion,and carrier 8) Non tilt auto column 9) Non tilt 4spd column 9) Van tilt column-short shift lever 10) NP205 Skidplate and crossmember 11) NP205/Rockwell T-case crossmember 12) Corp. 12 bolt rear with 3:73s (From 4wd) 13) 3:73 ring,pinion,and carrier from dana 44 front axle 14) Closed Knuckle Dana 44 axle parts-Shafts,etc 15) Gauge Clusters,non tach.Oil pressure,gas level,speedometer,temp. 16) 69-70 Truck Bucket seats-Drivers side needs some foam work and new cover,passenger side needs foam replaced and a new cover. 17) Center Consoles-Correct for 69-72s.No cupholders-Needs 2 holes filled in center section 18) Factory Slider rear window 19) Door internal parts ***Will Start a new thread to sell parts in*** Thanks for the help on any pricing of some of these parts.I need to clear some room and need to know some prices.. Dustin Last edited by 1969k10stepside; 08-11-2007 at 02:17 PM. |
never finish start another
Re: WIW-4wd parts,2wd parts,gears,emblems,bucket seats,consoles,etc
Interested in the 3.07 gears, but not sure what there worth.
![]() Join Date: Jun 2005
I'm interested in the np 205 crossmember and skid plate. I'll give $100 and first in line for any bumps!!!!!!!!!!!!!!!!!!!!!Thanks, Dan
What are you taking from the truck? I am looking to convert my 2wd to 4wd and need a good rolling chassis/frame. I might be able to buy the whole package from you. I will have a good 2wd frame that has been converted to an ls1 and 4l80e....If you would like to trade.
#5 | ||
They are still in the 12 bolt rear but if they are in good shape like I remember them being,I'll sell the ring,pinion and carrier for $30 obo pluus shipping
![]() Quote:
