Old 12-21-2002, 04:16 AM   #1
cwilkie
Chance
cwilkie's Avatar
TH 400 Kickdown Switch
I am looking for a TH 400 Kickdown Switch, 4bbl bracket, and cable. This switch is the one that mounts to carb. , like the ones in Camaros and Chevelles. Does anyone have one or know where I can find one?
cwilkie is offline   Reply With Quote
Old 12-21-2002, 12:05 PM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
My truck had an Edelbrock 1401 on it, and no linkage to the kickdown switch.
I bought a kickdown device from Lokar. I haven't installed it, yet. However, I had my transmission serviced, and also had the valve body modified for firmer shifts. They checked the kickdown switch in the tranny, and it is okay. I just need to get busy and get the Lokar piece installed. About $60. Go to www.lokar.com, for more info, or check with a hotrod shop in your area.
Oh, I've since changed to an Edelbrock 1901 Q-Jet. I still don't have the kickdown linkage hooked up, but the modified tranny will kick down, as determined by a lack of vacuum at this time. The modulator is the smallest canister that would work with my TH400. Only thing I miss, is the kickdown to 1st.
Member Nr. 2770
Old 12-21-2002, 01:08 PM   #3
crazy longhorn
Fabricate till you "puke"
The 400s will shift from 3 down to 2 without the elect kickdown. Mine is not hooked up......the thing kicked down to 1st a couple times when I throttled it a little around a corner, & those 4.10s tryed spinnin that longhorn in circles! thats a lot of truck to turn around with rear wheel steering
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-21-2002, 05:10 PM   #4
photoglg
photoglg's Avatar
Do you have the brackets for mounting the switch. Almost any switch will work. You just need a way to mount it. The TH400 is electic it does not use a cable. I mounted my switch on the floor and just step on it when I need to kick down a gear.
1969 GMC S/B S/S 3" drop
photoglg is offline   Reply With Quote
