#26 |
Born Psycho
![]() Join Date: Feb 2001
Re: Check out this bad 72
I'm not a fan of the chopped top either but my name ain't on the pink slip. the owner put a ton of time and dollars into that truck and built it how he wanted. i'm sure it's worth more than all my trucks combined
![]() i do like the pic without the chopped top better though ![]()
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
#27 |
Love It!!..
#28 |
I don`t chop my trucks tops,but I don`t customize`em that much,either.I wouldn`t condem every truck with a chop top.I try not to make blanket judgements,pretty close minded IMHO.You`ll find,generally,with that mentallity sooner or later you`ll eat you words or miss out on a good thing.
I like what they did with the glovebox door.I have had that idea,just haven`t done atruck since the idea popped up.I`d either do the G-box door in pebblegrain black to match the cluster or make a cluster from a g-box door and do what they did,chrome then paint center body color or interior color(like GMCs).I`ve chromed g-box doors and put the woodgrain in the center.
#29 |
Is it an automatic? (no clutch pedal)......
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! |
#30 |
no brain no headache
I think so, the shifter looks like one of the "Lokar" shifters.
The chop doesn't look all that bad on that truck but it still look disproportional.
1996 GMC Sierra z71 ![]() 1970 SWB 2wd (project) ![]() |
#31 |
I like the body mod's. I would like to see it with a little less of a chop.
My $.02
Dan |
#32 |
I kept thinking that I had seen this truck before... I think I found it when it had 15's and no airbags. In the March 1994 issue of Truckin'. When you consider that it was built in the early 90's, you can kind of understand why it has the chop top. Obviously, it's been updated and had the hood replaced. I do like that they got rid of the bulge running down the center of the hood though.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build Last edited by smbrouss70; 08-21-2007 at 02:25 AM. |
#33 |
looks good with the 15s too
to bad the gas door sticks out like a sore thumb though ![]()
1996 GMC Sierra z71 ![]() 1970 SWB 2wd (project) ![]() Last edited by 70c10swb; 08-21-2007 at 02:35 AM. |
#34 |
67 is sold
GD this is a tough crowd, for a second I thought I was on a Corvette forum
#35 |
About chop tops.I keep hearing they are disproportionate...DUH?Doesn`t any change in body dimension change the proportions?Isn`t it like saying painting a truck red makes it look red?
Sorry,but it annoys me how this board can stoop themselves to negative comments on a truck that`s nicer than most of us will ever know.To many this would be seen as crystal clear envy.We can all make a critical comment,including me I admit.But the pack mentality thing`s a real turn off.I`d just like to see everyone more aware of this and try to restrain jumpin`on the bandwagon.I caught myself doing it when I first joined.I am very opinionated,yet can allow others their tastes.Don`t take this as condecending,it`s meant as an attempt to raise a little more class out of the group.It won`t hurt...thanks
