Old 08-20-2007, 01:27 PM   #1
KB's-Slammed69
20" Wheels..... what offset do I need?
What offset do I need to go with 20" wheels on a 1969 Chevy C10? I'll be running 20's in the front and rear and need the offset. I just finished installing the Air Ride Suspension on the front and rear.
Thanks!
KB's-Slammed69 is offline   Reply With Quote
Old 08-20-2007, 01:59 PM   #2
cflvulcan
cflvulcan's Avatar
Re: 20" Wheels..... what offset do I need?
im not sure what offset is mine, its been a while. but i know mine are the same as a factory 73 and up chevy 4x4...
cflvulcan is offline   Reply With Quote
Old 08-20-2007, 02:38 PM   #3
72BlckButy
Tot Roddin'
72BlckButy's Avatar
First off welcome to the site!
In order to determine the correct offset is usually up to the owner or tire shop, and the type of wheel/tire combination in question. It depends on the wheels, the type of suspension (different rear axle, discs front/rear, and many other factors. You might find more information on the Suspension portion of the site, but you will get plenty of feedback here as well.
Also, try a search for backspacing on 20" wheels and you will find many other posts on this same topic. Good luck on the search, I'm having the same problem...
By the way...
Also cflvulcan, love how the truck turned out! Love that color!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 08-20-2007, 02:43 PM   #4
72 Cheyenne402
72 Cheyenne402's Avatar
You can search any of my threads and find all the information you need. I nearly beat this topic to death. Also try the suspention
1972 Cheyenne 402 LWB
2005 Silverado X-Cab 5.3L
2004 John Deere L120 20HP B&S
72 Cheyenne402 is offline   Reply With Quote
Old 08-20-2007, 02:44 PM   #5
KB's-Slammed69
Thanks for the help! I have air ride suspension, stock rear end, and disc brakes all around.
How do I post a pic?
Old 08-20-2007, 08:45 PM   #6
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
I think it's +13mm or +18mm.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 08-21-2007, 01:42 PM   #7
72 Cheyenne402
What width wheel are you going with? 8.5, 9.5, or 10.
