Old 12-18-2002, 06:54 PM   #1
gman
blower motor question
I've done a search on past posts but I'm still uncertain about the answer to my question. My blower fan starter whistling last night when I turn the fan on. I assume its the blower motor. My question is do I get this out from the engine side of the firewall, passenger side? I'd swear thats what my service manual said when I read it. But reading some of the past posts, I'm confused. Not sure if I need to get under the dash to get it out also. How difficult is this going to be? '72, 350, 4x4, fact ac. I get heat, not all that hot but I think I have a bad thermostat that needs replacing too. Any tips or things to avoid? Whats the proper way to do this? Is it absolutely necessary to remove hinge on pass side? Should I replace heater fan at the same time? If so, is that in same area as blower motor? Do I need to replace core? I think I'll open up the heater and duct work to see what goodies I find in there. Any help appreciated.
72 Chevy SWB Custom Deluxe K10, 350/SM465, PS, PB, Fact. Air
2000 Harley...Wide Glide
gman is offline   Reply With Quote
Old 12-18-2002, 06:56 PM   #2
72MARIO
72MARIO's Avatar
I think you need to remove the hood hing to put a new blower motor in if you have A/C not sure though.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 12-19-2002, 12:25 PM   #3
gman
ttt
Old 12-19-2002, 07:09 PM   #4
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
You have to remove the fan from the engine side. Its easier if your remove the hood and hinge on that side. Unless your heater core is leaking or its not warming up, I wouldn't mess with it. Good luck, Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 12-19-2002, 07:19 PM   #5
3damnboyz
3damnboyz's Avatar
remove the hinge, blower cage and motor are connected and will come out togeather. my heater core took a crap a year ago and i went in and redid all that stuff, inside and out! (really, if can just remove the bolts from the hood hinge at the fender you should be able to get the hinge and hood to move out of the way enough to remove the motor, just gonna need a little help holding the hood up while you work on getting the motor out)
72 short wide
55 stepside- 2nd generation
"come on honey, we need more old trucks to fix up for the boys to drive, they will be driving before ya know it!"
3damnboyz is offline   Reply With Quote
Old 12-23-2002, 11:52 AM   #6
gman
Thanks for the comments everyone. It helps a lot.
Old 12-23-2002, 12:06 PM   #7
mikep
Used to have a truck
mikep's Avatar
I did mine last night. Had to remove the hinge. I just propped the hood open with a broomstick and put a block of wood in the rear to support the hood. You'll need a 1/4 inch drive long extension and a universal joint for the socket.
I replaced my fan, the relay, and the resistor inside the airbox. Man, what a difference.
No truck :-(
mikep is offline   Reply With Quote
Old 12-23-2002, 12:16 PM   #8
chevy2racr
So Many Ideas, So Little Money
chevy2racr's Avatar
You say blower motor and I had my hopes up, I was ready to see a 871 blower in a trcuk :-D
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors
71 C10 with 454
99 S-10 5.1L SBC 700R4
09 Malibu
Marshalltown, Iowa
chevy2racr is offline   Reply With Quote
Old 12-23-2002, 12:32 PM   #9
wlee
Just an Old Mr Goodwrench
That bottom bolt on the blower cage is fun Most guys just break the cage, but it can be removed with out damage if you're lucky.
1969 CST 20 Longhorn
1970 CST 20 Fleetside
1991 Jaguar Sovereign
1992 Mazda Miata
wlee is offline   Reply With Quote
