Official Site Guitar Shredder
dimmer switch
hey guys quick question.. was driving the 67 today home from work...and my dimmer switch started smoking.....lol i had the headlights on,(brights) and i started to smell that great wire burning smell......lol i reached down and unplugged it ..smoked stoped but the wires was hot ? i ad to change this harness a month or so ago.....can anyone think of whats up....i put one i had liesing around back in it and ....after about 5 mins on the brights it did the same thing...im thinking i got a bad ground????? oh i am running the new tri bar headlamps would this change anything? thanks for any help tony
sufficiently talented fool
![]() Join Date: Jun 2006
Re: dimmer switch
The new headlights draw more current than the old stockers. Look at the board vendors to buy and install a headlight relay kit to fix the problem.
"it's impossible to be surrounded by idiots when you are part of the circle" ![]() 2003 Suburban 2002 Pontiac Montana 1981 Corvette 1966 Impala Convertible Click here to support the board |
Re: dimmer switch
so just buying a new stock switch wont be good enough? i baught the tri bars from good guy s in indy this year(not from a site vendor) funny how the never mentioned<spell anything of the sort,,, (IT LL BOLT RIIIGHT UP TO YER FACTERY EVERYTHANGS) ......sorry had to vent a little thanks centsless
![]() ![]() Join Date: Jul 2002
Re: dimmer switch
Run the relay kit. Even if the replacement dimmer would handle it, you are much better off with the relay setup. It'll make your lights brighter and put a lot less current passing through that old harness.
Edit...BTW the tribars will hook up, but it is recommended to have the relay setup because of the extra draw. Don't always believe the salesman!
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 08-20-2007 at 10:36 PM. |
'69 Step
Re: dimmer switch
ditto on the relay kit; best 25 bucks spent on the truck so far
It's my truck, and Yes, I CUT the dash, so what?? |
its all about the +6 inches
Re: dimmer switch
even with sealed beamns, the improvement was.. well... night and day.
Re: dimmer switch
wires currently in use are not ample enough to hold the current, need to update wiring, everyone is right. not that i'm an expert but i do electrical work for a living
Re: dimmer switch
SSSSSSSSSSSMOKIN!!!!!!!!!!!!!!!!
Do the relay thing. ![]() |
Re: dimmer switch
Re: dimmer switch
Kit should come with complete instructions. They are pretty straight forward.
Re: dimmer switch
lol it didnt come with anything ..lol but lights.........
Between Trucks...
Re: dimmer switch
Anybody have a link to these relays?
Beat it to fit, Paint it to match... ![]() |
Re: dimmer switch
Try Mad Electrical
They not only have the kits, but a ton of useful information http://www.madelectrical.com/electri...adlights.shtml
Re: dimmer switch
thanks guys i really appreaciate<spell it... im going there now....ill let ya know what i find
thankss again tony |
#15 | |
Re: dimmer switch
sorry...
#16 |
Re: dimmer switch
i want to thank everyone for chimming in on my dimmer switch issue> or the addition of my tri bars......got my relay kit ordered....33 bucks shipped.......hopefully i ll get it this weekend , i hate not driving my 67 at night........thanks again ......tony
#17 |
Re: dimmer switch
I did mine off a post in this forum. I actualy did it on a CJ5 Jeep, but will do on the Chev also. The difference was VERY noticeable. I put mine together at the Napa store from their lighting catalog for like off-road lights. I made a simple mounting plate for the relays, mounted it on a fender and re wired accordingly. Probably the Mad electrical would save you a lot of running aroun though. The amp rating for the relays was a little bit hard for the Napa guy, If you go this route i am sure you don't save but maybe 10 bucks and the shipping from Mad .
If you choose the parts counter route, just tell the parts guy that it is in the off-road lighting catalog. ![]() |
#18 |
It's a catastrophic success.
![]() Join Date: Jan 2003
Re: dimmer switch
Here are a couple of diagrams(2 or 4 lights) if you want to make up a kit yourself.
#19 |
Re: dimmer switch
so this set up basically eliminates my headlight switch?
#20 |
Re: dimmer switch
No, it does not eliminate anything. What it does is instead of all of the current the headlights use going through the switch and dimmer only go through the relays. The headlight switch and dimmer switch will simply control the relays which are very low current. All of the high current load will only pass through the relay.
#21 |
Re: dimmer switch
Like he say. Kinda brings the 60s up to modern times lighting wise.
#22 | |
![]() Join Date: Nov 2006
Re: dimmer switch
Does anyone know the difference between this kit and the one that the LMC catalog offers that already has 2 relays included? http://www.lmctruck.com/icatalog/cb/0153.asp Thanks for any help on this from someone who is clueless and learning. ![]() |
