Old 08-23-2007, 11:03 PM   #1
hemihead
hemihead's Avatar
Question Posi with 3:73 - will this work?
I bought this posi on ebay. I was expecting the clutch type posi but have something I haven't seen before. The add said it was for a 12 bolt truck diff. Can someone help me out and tell me what I bought?
I have it going in my 67 SWB which currently has a 3:07 open diff.
hemihead is offline   Reply With Quote
Old 08-23-2007, 11:26 PM   #2
centsless
sufficiently talented fool
centsless's Avatar
Re: Posi with 3:73 - will this work?
That looks like a no-spin rear. Also referred to as a gov-bomb.
"it's impossible to be surrounded by idiots when you are part of the circle"
2003 Suburban
2002 Pontiac Montana
1981 Corvette
1966 Impala Convertible
Click here to support the board
centsless is offline   Reply With Quote
Old 08-23-2007, 11:40 PM   #3
BCOWANWHEELS
Its A Eaton Gov Lock And It Will Do Fine Unless You Jerk It Around All The Time. They Get A Bad Rep Cause You Cant Beat Them To Death. Good Driver Quality Diff.
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 08-23-2007, 11:51 PM   #4
69TowRig
It is an Eaton Gov-Lock ("gov-bomb" moniker above). It is not a Detroit No-Spin, up until very recently they weren't even made by the same company. Those parts you can see in the picture are part of the centrifugal weight system used to engage a set of dog-clutches to lock the differential.
This is yet another one of the on-going sagas with the wrongful use of the word "posi". Posi is an Eaton trademark, always has been, for their clutch-type limited slip differentials. I think in the world of automotive nomenclature the word "posi" is one of the most generalized and most time incorrectly used of all time. My own brother refers to "posis" as the two-tracks left by his Chevelle on asphalt after he prods the gas pedal.
-Chris
Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid.
Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals...
69TowRig is offline   Reply With Quote
Old 08-23-2007, 11:59 PM   #5
hemihead
hemihead's Avatar
My 67 is a daily driver, back to forth to work, town trips, and the odd road trip. It might see the odd burn out and launch but thats about it. Paid $122 shipped with the 3:73 gear set.
Should I keep or resell and see if I can get my hands on a clutch type posi?
Old 08-24-2007, 12:03 AM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
You should keep the gears and sell the truck.......to me.....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-24-2007, 12:33 AM   #7
72armyswbtruck
72armyswbtruck's Avatar
N2TRUX one of these days someone is going to take you up on your offer.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 08-24-2007, 12:39 AM   #8
BCOWANWHEELS
Keep It And Run It.........
Old 08-24-2007, 01:07 AM   #9
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
Welcome From Indiana, Your Truck is Really Nice..............
Thanks, Rick
toomanytoyz is offline   Reply With Quote
Old 08-24-2007, 02:47 AM   #10
GREASEMONKEY72
GREASEMONKEY72's Avatar
WELCOME to the board
i say just run it, you can always change it later if you dont like it
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 08-24-2007, 06:26 PM   #11
hemihead
hemihead's Avatar
Thanks for the comments, I have since dropped the truck and re-wired the truck with a Painless kit.
Thinking about 700r tranny this winter and getting rid of the drums for discs with power brakes. So since I will be in the rear end I will get rid of the 3.07 open carrier and put in the 3.73 gov lock.
The current T350 seems to only hold rpm to 3000 and then shift so it definitely needs a rebuild.
The cab has some minor rust issues which need attentin but that will likely be the last thing I touch.
