Old 08-25-2007, 12:19 AM   #1
redrat
gearhead
redrat's Avatar
what are these for ?
What are these spacers in the first picture? (the one between the alingment shims and the frame) do they come with the drop spindels or drop springs to make the suspinsion geomitry correct? Look in the second picture and they are not on a stock set up. Im ready to put the front end back together, but im using drop spindels and drop springs. I want to make sure i get this right the first time. Thanks for the help guys.
2003 GMC Z71 Daily driver
1982 Chevy 2wd short bed, project,
boxerdra@hotmail.com
redrat is offline   Reply With Quote
Old 08-25-2007, 12:23 AM   #2
SCOTI
SCOTI's Avatar
Re: what are these for ?
They're just that..... spacers for alignment. Using them reduces the number of shims required when aligning a vehicle that's been lowered w/drop or cut springs.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-25-2007, 06:30 AM   #3
Mr79C10
It Is What It Is,,,,
Mr79C10's Avatar
SCHAWEEEEEET,, Where do I get a set?
*79 C10 Short Box ST8 6 bang'r *
*Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT
*__--__*
79 C-10 project
.........................__
..............._____ l __\___
..............|_(O)_ |___(O) ]
FAQ INDEX Thread
The Kulture
My Rat Den
Mr79C10 is offline   Reply With Quote
Old 08-25-2007, 06:32 AM   #4
Mr79C10
Mr79C10's Avatar
Question...... Can those bolts be replaced with longer ones? Im thinking since I went the LCA route I might need just a wee bit extra tweak out of it..
*__--__*
79 C-10 project
FAQ INDEX Thread
The Kulture
My Rat Den
Old 08-25-2007, 04:39 PM   #5
redrat
gearhead
redrat's Avatar
Yes they can be replaced. I kept the long bolts when I took that k-member apart. The bolts are about 1/2 longer. The good thing about that spacer is it ties them both together. It makes it stroger in my opinion.
Old 08-25-2007, 04:49 PM   #6
redrat
gearhead
redrat's Avatar
Just a sugestion.. You may want to move the square washer with the one round side out to the upper controle arm shaft. The round side of the washer fits int the grove in the shaft. I just noticed this problem on mine as well.
Old 08-25-2007, 05:19 PM   #7
Mr79C10
Mr79C10's Avatar
Ummm,, oh yeah, your right,,, Hmmmm, project for a weekend around the corner.
*__--__*
79 C-10 project
FAQ INDEX Thread
The Kulture
My Rat Den
Old 08-26-2007, 09:19 AM   #8
swissfacade
swissfacade's Avatar
You might want to look into A-arm spacers (aluminum) it is what all of the racers use, I would think if it is strong enough for racing it should be ok for street use. You just need to know what the bolt center is and the thickness you want. Here is one of many websites that sell them. Hope this helps? John
swissfacade is offline   Reply With Quote
Old 08-26-2007, 01:36 PM   #9
Mr79C10
Mr79C10's Avatar
Like this
*__--__*
79 C-10 project
FAQ INDEX Thread
The Kulture
My Rat Den
