Old 08-26-2007, 02:19 PM   #1
jandj_davis
Re: Hard starting when cold
The last two days I have been "priming" the carb (SLOWLY pumping the pedal while the starter is cranking, usually 1 pump every 2 sec.), and the truck has started great. About 5-6 seconds of cranking. That seems reasonable to me. I'm glad it was a "technique" problem and not a mechanical problem. Technique problems don't cost anything to fix. Now I just have to figure out where the gassy smell is coming from. I just replaced the fuel filter, is it common for that joint to leak?
jandj_davis is offline   Reply With Quote
Old 08-26-2007, 03:03 PM   #2
Malo83
Cruzzzn' Vet
Malo83's Avatar
get that fixed right away
Malo83 is offline   Reply With Quote
