Old 08-23-2007, 08:57 PM   #1
cmg27
Blower Relay Hot! No HI Speed...
On a '72 with factory air is it normal for the blower relay to get hot while in use? I noticed this while trying to figure out my HI speed not working. Weird thing is that I bought a brand new GM relay, installed it and it did nothing??? Didn't work on any speed. The new part looks exactly the same, just doesn't work at all. Anybody else run across this before? I'm assuming the original relay is bad as everything else works fine. LOW and MED speeds work, HI seems like it goes back to LOW. All connectors and wires look nice, nothing burnt or melted and all grounds are clean. Any ideas?
TIA
Grant
cmg27 is offline   Reply With Quote
Old 08-23-2007, 09:04 PM   #2
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Re: Blower Relay Hot! No HI Speed...
Where was the relay located that you replaced? The high speed fan relay is located next to the inside firewall. Mounted to the heater core housing. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 08-23-2007, 09:10 PM   #3
cmg27
Wes,
Yes, that was the one. Mounted on the heater core housing far right side.
Thanks!
Grant
Old 08-23-2007, 09:32 PM   #4
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Don't know about the relay getting hot, but my high speed doesn't work either. I've replaced the switch (twice), the resistor and the relay and still no luck. I guess the next step is the wire harness or the blower motor itself.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 08-23-2007, 10:48 PM   #5
jhow66
jhow66's Avatar
Your high speed works off this wire from fuse panel. Check to see if it has 12 volts at all times. Also they get loose at fuse panel and heat up causing a corroded conection.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 08-23-2007, 11:32 PM   #6
Stocker
20' Daredevil (Ret)
Stocker's Avatar
When my high speed stopped working, it was just a bad switch... iirc, I got a new one from NAPA.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 08-23-2007, 11:39 PM   #7
Bob B.
Yes, that relay has to be grounded. There is a ground wire in he harness going to the relay. It has a ring terminal, and should be under one of the relay attaching screws.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 08-23-2007, 11:47 PM   #8
cmg27
jhow66, I don't understand the fuse box picture. The red wire I have is only for the cig lighter, although there is an unused female connector off of the same wire near the fuse box end. Is there supposed to be something plugged in there? I have no extra connections at the relay?
Grant
Old 08-24-2007, 12:03 AM   #9
paaw
paaw's Avatar
let me know, because I replaced blower motor, relay when I iput new relay in and grounded it to the glove box door, didn't do any thing on high, what it the wire by itself on the relay for, because low and med work when it is not hooked up of grounded. thanks in advance
CHico
1997 pontiac grand prix gt (daily driver) for now; 2004 dodge ram quad cab (wife's truck) 4.7; 2000 pontiac booneville (wife daily driver) 1972 chevy cheyenne 350 bored 40 over 700r trans 373 gears ( posi) soon to be daily driver; 2002 gsxr750 sold
paaw is offline   Reply With Quote
Old 08-24-2007, 12:18 AM   #10
jhow66
jhow66's Avatar
That wire feeds both. Female plug is for some acc. Check the wire at relay to see if it has 12 volts. Trace this wire from fuse panel to relay. Does cig. lighter work? If it does, take a jumper wire and ground the relay to a good ground and try it.
For AC to work on high, all levers have to be to far left. When you put the fan switch in the "HI" postion this shuts a switch inside relay that connects the "red" wire from fuse panel to the "purple" wire that goes to fan motor by' passing the resistor for "lo" and "med". To check to see if your fan motor will run on high, disconnect the wire from fan motor and run a jumper from battery "+" to connector on fan motor. If it does not that is why your relay is getting hot. To me, it sounds like the relay is not grounded. Try this and let me know the results.
Old 08-24-2007, 12:41 AM   #11
cmg27
jhow66,
So is the cig lighter end of my red wire supposed to have more than just the lighter connector on it? I still don't understand where the separate power is supplied from and I have no available terminals left at the relay. My relay has one connector of three wires, one single connector with a smaller size orange wire and the black ground wire with eyelet. Maybe my problem is at the other end of that ground wire, wherever that is? I'll try your suggestions and let you know.
Thanks for your help!
Grant
Old 08-24-2007, 10:58 AM   #12
jhow66
jhow66's Avatar
Look at this diagram and see how the wires run. Plus read this thread. Will check mine out and see if I can make it easier for you.
http://67-72chevytrucks.com/vboard/s...wiring+diagram
Old 08-24-2007, 10:59 AM   #13
jhow66
jhow66's Avatar
Got to go. Be back later .Need more info just ask.
Old 08-24-2007, 12:19 PM   #14
Baby John
Well, I can't provide any info except to say that I have a Vintage Air system in our truck and though it will run on high for a short time, it will eventually heat up and the relay will kick off.
It won't happen on med or low. I felt of the switch when it shut off and the switch itself is really hot.
Baby John is offline   Reply With Quote
Old 08-24-2007, 09:53 PM   #15
jhow66
jhow66's Avatar
cmg27 see if this will help any:
Old 08-24-2007, 10:29 PM   #16
cmg27
Thanks for those exploded diagrams! I can see that the lighter harness is like mine, just a single red wire directly to the lighter from the fuse box that only feeds the lighter. In the first diagram I cant read most of the text, but appears to show an orange wire also plugged into the "cig" receptacle. I see no signs of that orange wire under my dash? Is there any chance that '72 is different than '71? You've been very helpful and I really appreciate it! Hopefully I can get this figured out! I have an original 1972 GMC service manual on the way.
By the way, my blower motor works fine at high speed, I jumped the wires at the relay and it went to high speed.
Grant
Old 08-24-2007, 11:14 PM   #17
paaw
paaw's Avatar
cmg27 what wires did you jump to make it run on high
Chico
Old 08-24-2007, 11:49 PM   #18
cmg27
paaw, it was within the three wire connector at the relay. I believe the orange wire is main power and jumped to purple for high speed. Same as running a jumper wire from + battery terminal directly to blower motor. Be careful!
Grant
Old 08-25-2007, 01:24 AM   #19
jhow66
jhow66's Avatar
Did truck come with AC? If so there should be a wire (red or orange-#12 gauge) running from the "cig" spot (cig will plug into the pigtail) to the relay. This supplies power to the relay and cig lighter at all times. When you move the fan switch to HI with all levers to left (for AC) it powers the relay to connect this wire straight to the wire going to fan motor. This way the fan motor gets a full 12 volts. Is all the spades filled on your relay? If so trace the large orange or red wire back toward fuse panel. It probley has been disconnected and stuck up in the tangle of wires under dash. Keep asking questions. Have wired cars from scratch making my on fuse panels and connections so should be able to help you find your problem. Just keep answering and asking.
Old 08-25-2007, 09:47 AM   #20
cmg27
Yes, factory a/c. All spades at relay are filled. The orange 12 gauge wire is part of the harness/connector (3 prong) at the relay. Its factory wrapped and I havent tried to trace it yet. My red wire from the "cig" connector at fuse box goes directly to lighter and is a separate harness/wire by itself, feeds nothing else. It just sounds like a different setup than what you are describing. I'll take some pictures tonight or tomorrow and post them.
Thanks again!
Grant
Old 08-25-2007, 10:36 AM   #21
cmg27
Here's a picture of a lighter harness like mine.
Grant
Old 08-25-2007, 02:31 PM   #22
paaw
paaw's Avatar
cmg27 have you tried unhooking your jumper wire, jumped min cut on high and then back to low did this three times, then tried it with out the jumper and now my high works with out the jumper
Chico
Old 08-25-2007, 09:24 PM   #23
cmg27
paaw, I never left the jumper wire in place, just used it to test the hi speed that way. So you say that after jumping the orange & purple wire on the 3 wire plug three times it started working by itself? Thats interesting!
Grant
Old 08-26-2007, 12:03 AM   #24
paaw
paaw's Avatar
works like a charm, i guess the relay just needed a jolt, i grounded it to the inside glove box screw, tried it again while ago works fine
Old 08-26-2007, 08:54 PM   #25
cmg27
Well, as it turns out the new GM relay was the wrong one and the original was definitely bad. Went to Napa today and bought another relay, put it in and everything works great. Doesn't get hot either! Cant always assume that you have the right part just because it looks right. Lesson learned.
Thanks to all for your help trying to get this solved!
Grant
