Old 08-26-2007, 09:38 PM   #1
stefan
New Member
belltech spindles
has anyone ran belltech 3 inch spindles on a 67-72 chevy truck i heard they have a 3inch drop spindle for a 73-87 chevy truck that can be used on a 67-72,just wondering if anyone ran them and what mods were required.
stefan is offline   Reply With Quote
Old 08-26-2007, 10:42 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: belltech spindles
stefan,... What year truck are working on? The spindle will work if you use '73-up balljoints and '73-up outer tie rod ends. The problem you might have is,... connecting the outer tie rod to the stock inner. If you have a '71-'72 truck the '73-up outer will bolt right on. If you have a '67-'70 you will need and adapter sleeve to connect to the '73-up outer tie rod. (Can't remember the company that makes them. Maybe ECE) Confused yet. I did this swap along time ago on a '69 burb I had. If you have to BUY spindles,... it's easier to just go with the ECE (early classic enterprises) spindles for the correct year.
Keith
Convert to disc brakes.
Old 08-26-2007, 11:59 PM   #3
edflores
you can just sell me those spindles.
edflores is offline   Reply With Quote
Old 08-27-2007, 09:12 PM   #4
stefan
New Member
i have a 72 and i have belltech spindles and i have 73 upper ball joints and 73 outer ty rod ends the lower ball joints are the same for 72 or73 so i think i got it all i just hope all the brake stuff fits.
Old 08-27-2007, 11:15 PM   #5
lolife99
lolife99's Avatar
Sound like you got it figured out. '71-'72 trucks are the easiest to use the '73-up spindles on. Brakes shouldn't be a problem. I don't know what size rims you are running up front,... But I would suggest trimming the lower a-arms and trimming the bumpstop brackets. Then you should be fine to run any size wheel.
Keith
