Old 08-26-2007, 03:48 AM   #1
cameeks
Long Fleet Club
cameeks's Avatar
Unhappy I came home from work but the truck didn't
Please help. My tach started acting up. Then later the engine cut out then a really loud back fire when it started going again. After that the next day it was hard to start at first but when it started ran fin for 12 min until I got to the property of work then started bucking. drove it to my parking spot and that is where it sits.
Could this just be the coil. I have power at the main power wire but no spark at the plug (checked with the screwdriver method). Coil came out of my old Camaro so it is about 6 or 7 years old.
Chris Meeks
'69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling.
Truck is now finished to the new owners design and running around.
I was shown some pictures of the finished product. At least it survived the junk yard.
FAQ Index by Krue Site Vendors Subscribe Here Forum Rules
cameeks is offline   Reply With Quote
Old 08-26-2007, 03:59 AM   #2
JHART
1972 Shorty Owner
JHART's Avatar
Location: Stationed in Cali , born and raised in PHX Arizona.
Re: I came home from work but the truck didn't
Hei ?
1972 Chevy Shorty C-10- Project In Work
http://67-72chevytrucks.com/gallery/...ATT1721941.jpg- New Project
JHART is offline   Reply With Quote
Old 08-26-2007, 04:01 AM   #3
cameeks
Long Fleet Club
cameeks's Avatar
correct
Chris Meeks
Old 08-26-2007, 04:02 AM   #4
JHART
1972 Shorty Owner
JHART's Avatar
Its either that or the ignition madule ... does the truck turn over at all?
Old 08-26-2007, 04:04 AM   #5
cameeks
Long Fleet Club
cameeks's Avatar
It has an accel coil like this (not mine it is a pic from the internet)
Chris Meeks
Old 08-26-2007, 04:05 AM   #6
cameeks
Long Fleet Club
cameeks's Avatar
yes and replaced both plug in pieces when I rebuilt the upper half last year.
cant remeber part names
Chris Meeks
Old 08-26-2007, 04:07 AM   #7
JHART
1972 Shorty Owner
JHART's Avatar
Well it could be either on ... but i would go with control module first its cheaper ..hehe
But def sounds like a coil/module prob.
I have that same coil on my truck.
Old 08-26-2007, 06:40 AM   #8
Because the tach gave the first indication,I`d look at the supply to the ignition.It backfired because it lost power then went back on.Check the sheathing on the dbl wire from the distributor up to the cap.It bends pretty tight and I`ve seen the insulation break through.I did all the guts in my HEI and my truck still just cranked.Actually I went through two modules within two weeks,first.I discovered if I bent those wires tight I could see that greenish oxidized copper color.Took the wire off a junk truck and sped off.
*I had the Accel coil,too.
Old 08-26-2007, 01:24 PM   #9
cameeks
Long Fleet Club
cameeks's Avatar
Well I'm going to buy a new coil and I think the module has a life time warranty. Going to try that first.
Chris Meeks
Old 08-26-2007, 01:27 PM   #10
cameeks
Long Fleet Club
cameeks's Avatar
Are you talking about these wires on the side?
Chris Meeks
Old 08-26-2007, 02:23 PM   #11
OlChev67
Ever heard of Beech Island??
OlChev67's Avatar
check all wire connections and wires to the hei, sometimes the biggest headaches can be the smallest loose wire. if still runs bad coils are pretty cheap.
OlChev67 is offline   Reply With Quote
Old 08-26-2007, 02:35 PM   #12
byrd
Union Electrician
byrd's Avatar
Yep he is, I have the same problem as you described and I did the coil,module and capasitor replacement and it worked for a day or two( I guess I cleared the short when I pulled the cap) and then the same cutting out and backfiring. I put a new ign switch,wiring pigtail for the switch, new power wire to the dizzy and finally pulled it out and swapped it for a $50 65K volt dizzy from White performance off ebay and I have been trouble free for over two years now When I pulled it out of the truck I then noticed the insulation was broken and there was the tell tale green patina that copper does when exposed to moisture and was like AARRGH!!! It was those little wires the whole time. I think the PO pulled the old HEI dizzy from a boneyard and no tellin how old it was.
So if you have to buy a new coil and module I was just buy a new dizzy from white performance and toss the old one, as you will spend about the same amount of money and most likely getting a little hotter spark from the 65k volt coil. Just my .02.... Randy
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 08-26-2007, 02:49 PM   #13
Yes,those.If not those,also the ones that come off the harness.Don`t throw parts at it until you`re sure you have continuity though those.It`s very likely that.Usually when a module goes it will work until it heats up,then cut out.The vehicle cools and everything seems better,until it warms up again.I replaced the pick up and two modules before figuring it out.
Let us know how it goes.
Old 08-26-2007, 03:07 PM   #14
cameeks
Long Fleet Club
cameeks's Avatar
it sat for 10 hours and still didnt fire up last night
Chris Meeks
Old 08-26-2007, 03:37 PM   #15
You know,when I first saw this title I thought about how I always have said these trucks have always gotten my home.Then I read your post and remembered my HEI woes and how that`s the only time.I was cussin` electronics.They either work or nothing.I`ve never had points leave me walkin`.I use HEIs andthat`s about the only electronics.But,I can honestly say over many years that point have never given my anything to complain about.I`ve had trucks that sit all winter and occasionally driven in summer that I never opened the distributor on in over 10 years.The price we pay for maintainence free.You can always keep a set of points in the glovebox.
Old 08-26-2007, 06:06 PM   #16
jay6891
Car Knocker
jay6891's Avatar
What kind of tac you got. My Mallory from time to time will act up and you have to use a screw driver and rotate the 4-6-8 switch in the back to fix it. Sent it in once to have fixed and that is what they told me to do from now on. Corrosion between the contacts on the switch and rotating it 180 degrees shines it right back up. I would check my connections for the ignition system before throwing parts at it.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit.
jay6891 is offline   Reply With Quote
Old 08-26-2007, 08:33 PM   #17
Boog
laying low
Boog's Avatar
I had a similar problem with one of my trucks. It would just die going down the street. Sometimes start right back up and sometimes not start for 3 days. I stumbled on to the problem while checking the wires. I moved the wires that come out the side of the dist housing and it started. While it was running I moved them again and it died. Bingo! Apparently a broken wire in that block where they exit the dist housing and go up to the coil. Replaced that harness and all was good. Maybe yours is that simple.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 08-27-2007, 02:59 AM   #18
cameeks
Long Fleet Club
cameeks's Avatar
well bought the cap, rotor and coil becouse it was really old and needed to be done. Still dont fire off. I checked all connections and to see if I was getting ground and power to the coil and I am. The compasiter is some what new becouse the old one had dry roted wires. I'm guessing modual or new distributer.
Chris Meeks
Old 08-27-2007, 03:17 AM   #19
GREASEMONKEY72
GREASEMONKEY72's Avatar
must be the modual, so yea try that first for sure and let us know
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 08-27-2007, 03:21 AM   #20
cameeks
Long Fleet Club
cameeks's Avatar
With the amount of time I have and only being able to work on it after work in the parking lot at 1:30 am I think I'm just going to buy the lower half of the distributer and get it home. been working 7 10's and looks like rian might be in the forcast for this week. so right now my DD is pictured in the avatar.
With my luck it still wont work
Chris Meeks
Old 08-27-2007, 11:37 AM   #21
wibilly
wibilly's Avatar
i would guess its the wires from the pic up coil under the plate where the modual mounts they flex as the vacume canister alters ignition timing and over time they fail. i've had this problem before. a new picup coil and you should be good to gobut as said before a complete distributer with all parts right down to cap and coil can be had for about $70. if i rember right to change the picup coil the gear must be removed from the bottom and shaft pulled out from top to get the plate off
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 08-27-2007, 12:09 PM   #22
DTerry
'70 GMC C-25 LWB
DTerry's Avatar
Might sound strange, but try to unplug the tach wire at the dizzy. Happened to me once coming home from school in my camaro, it just shut off going about 40mph. tryed new caps, rotors, wires, everything even a whole new dizzy. Then put the old one back on and didnt hook up the tach and it fired right up. I was getting ground through the tach wire cutting off the ignition. Just a thought.
1970 GMC C-25 LWB (middle of frame up)
5-7 drop with 3in drop spindles, flip kit with blocks and still keeping the 3/4 ton. Shaved drip rails and marker lights, rear roll pan, cowl induction hood.
1987 Camaro z28
350, vortec 305 heads. 10:1 comp, t5 trans. Street terrrorizer.
1988 Monte Carlo (Super Stock ashpalt race car)
My Truck
DTerry is offline   Reply With Quote
Old 08-27-2007, 01:29 PM   #23
cameeks
Long Fleet Club
cameeks's Avatar
Didn't think to mention that when I was trying the connections that I didn't hook the tach back up. Didn't want to keep messing with it until I got it running
Chris Meeks
Old 08-27-2007, 01:38 PM   #24
cameeks
Long Fleet Club
cameeks's Avatar
Well got it back home by replacing the distributer. So with the parts that I bought befor and this part today (lower half) the whole thing is new now. On the way home I lost all electronics in the truck except the engine. Got it home and started looking around and found this.
Chris Meeks
Old 08-27-2007, 05:31 PM   #25
Aarons72s
Chris, sounds like you arent having to much luck. I hope that is the only part that melted. I lost the hole front harness to an electrical short. I wish you luck.
Aarons72s is offline   Reply With Quote
