08-26-2007, 08:31 PM | #1 |
flip kit..hows it work?
i got these parts,i do have 2 of each plus shock mounts.i know i need a c notch too.but there is no instructions on how to flip the rearend on top of the springs.i got these from a friend who didnt use them off a 2000 silverado.i was hopeing they would work on my 64.since it to has leafs.any ideas,suggestions would be appreciated. Last edited by satin64; 08-26-2007 at 08:32 PM. |
08-26-2007, 08:45 PM | #2 |
Re: flip kit..hows it work?
not sure on the 64.
Here's a link to djm install instructions, It's pretty easy, at least on my 86 it was. http://www.djmsuspension.com/Instruc...p/FK1024-5.pdf
1986 C10 SWB 6.0/6l90e Miami...Flee it like a native |
08-26-2007, 08:54 PM | #3 |
thanks, now for some reading....
if i got longer u bolts,would it be safe to add a 1 or 2 inch block? Last edited by satin64; 08-26-2007 at 08:56 PM. |
08-26-2007, 09:03 PM | #4 |
Active Member
if i got longer u bolts,would it be safe to add a 1 or 2 inch block?[/QUOTE]
It has been done many times before so I think you will be good. Jack
68 Chevy Long utility bed. Now swb/Bagged Soon to be 468 (Maybe 496) BB/Turbo 400 |
08-27-2007, 12:54 AM | #5 |
what about the spring perches???do i cut them off?or???
08-27-2007, 11:59 AM | #6 |
Active Member
Some flip kits use them to set pinion angle with the new parts. If your kit doesn't you can leave them or cut them off.
Jack
08-27-2007, 03:04 PM | #7 |
i dont think this kit does use them.kit is a lose term since it came off a truck that was switching to bags.guess i'll have to just do it and see what happens.
