Old 08-26-2007, 06:40 PM   #1
So.Cal.Super
It'll Buff Out!
So.Cal.Super's Avatar
Need Help With Divorced Choke Rod
I put up a listing in the parts classified looking for one and got great help, ideas and pictures on where/what/when to look for but have not been able to find any. called multiple vendors and parts stores but all I can find are the rods if your using the edelbrock performer intake. my only other option is I found a company that makes an electric replacment has anyone used/using this? my q-jet is on a 72 400 BB.
I've read multiple subjects on this from past topics and still can't seem to find them.
any and all help is much apreceated.
"Instructions are just another mans opinion"
Become a Supporting Member
http://67-72chevytrucks.com/vboard/payments.php
Man Card Rules
http://67-72chevytrucks.com/vboard/s...d.php?t=634550
72 Chevy Cheyenne Super 400 LWB
So.Cal.Super is offline   Reply With Quote
Old 08-26-2007, 08:17 PM   #2
uncle
Re: Need Help With Divorced Choke Rod
You might look on ebay for big block carbs and email the seller and ask about the choke. That is if you're not in a big hurry. Those parts get chunked and misplaced very easy since they are not permanently attatched to the carb.
uncle is offline   Reply With Quote
Old 08-26-2007, 08:22 PM   #3
JimKshortstep4x4
My suggestion would be to make your own rod using steel rod of the right diameter.
Electric chokes work very well on the later stock Q-jets so I would assume a conversion choke would work well also.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 08-26-2007, 09:36 PM   #4
69TowRig
Head to your helpful local hardware store (a real, old-school hardware store!) and buy a rod and bend it up.
-Chris
Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid.
Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals...
69TowRig is offline   Reply With Quote
Old 08-26-2007, 09:55 PM   #5
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Not sure about the '72 divorced choke, but on my '71 it wasn't available.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 08-26-2007, 11:25 PM   #6
Nelson
I used a metal coat hanger to make one time. It worked.
It's worth a try, even just to practice until you get some metal rod.
good luck.
Nelson
1970 C10 350 Auto.
A/C not Working
Nelson is offline   Reply With Quote
Old 08-27-2007, 03:28 PM   #7
So.Cal.Super
It'll Buff Out!
Thanks for the advice all, I don't think I want to try to build one myself. I think I am going to try the Electric choke conversion since the Edelbrock I have on it now already has an electric choke on it. the wire should just plug right in. when I get it on and installed I will let you guys know how it works.
Man Card Rules
Old 08-27-2007, 03:42 PM   #8
kwmech
I've done that several times without any issues, both for my own and customers cars
