Old 08-27-2007, 11:36 PM   #1
xshadow
Please help Will it work or will there be problems ?
will a complete break system from a
3/4 ton with drum brakes work on a 1/2 ton 4x4 with disk?
I want to use just about everything from the 3/4 ton 2wd....power breaks.. booster,master cylinder,proportioning valve. everything except for some new brake lines, and put it on the 1/2 ton 4x4 with disk break truck.
xshadow is offline   Reply With Quote
Old 08-28-2007, 01:16 AM   #2
wibilly
wibilly's Avatar
Re: Please help Will it work or will there be problems ?
the booster will work but i would not count on anything else
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 08-28-2007, 01:21 AM   #3
WORNBRAKES
Master cylinder might work but not the Prop valve.
Mario and Mandy
Hughesville, MD 20637
69 C10 305/350
71 K5 Basket case
75 K10 Rescue **Parting out**
77 MG Midget **Parting out**
15 6.7L Cummins
WORNBRAKES is offline   Reply With Quote
Old 08-28-2007, 07:49 PM   #4
xshadow
has anyone done this?
