Old 08-28-2007, 07:22 PM   #1
bdmcgee
bdmcgee's Avatar
Question Changing Oil
This is a dumb question, but I just got a 69 GMC pickup. It has a 396 which has been modified. I changed the oil and much to my surprised it only took 4 quarts. The mannual says 5. . . . any ideas? Thanks
bdmcgee is offline   Reply With Quote
Old 08-28-2007, 07:34 PM   #2
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Re: Changing Oil
You forgot the filter?
sorry, too easy.
Welcome to the forums!
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 08-28-2007, 07:38 PM   #3
cdowns
cdowns's Avatar
Re: Changing Oil
wrong dipstick
Old 08-28-2007, 07:44 PM   #4
msgross
msgross's Avatar
Re: Changing Oil
did you start it, shut it down and check again? might need to fill the filter...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 08-28-2007, 07:59 PM   #5
Sport/Truck
Sierra Grande Club
Re: Changing Oil
Does the oil pan look to be original?
s/t
Old 08-28-2007, 07:59 PM   #6
mvfd70
mvfd70's Avatar
Re: Changing Oil
Yup...filter takes about a quart to fill it
1978 Chevrolet Silverado 3/4 ton 400 small block.
2000 F-250 Powerstroke
2002 GMC Yukon Denali XL
mvfd70 is offline   Reply With Quote
Old 08-28-2007, 09:17 PM   #7
bdmcgee
bdmcgee's Avatar
Re: Changing Oil
Thanks for all the quick answers guys. . . Yep, there's a filter on it.(LOL) . . I don't know if it's the right dipstick and oil pan or not. I'm stump ed.
Old 08-28-2007, 09:40 PM   #8
mnunn454
mnunn454's Avatar
Re: Changing Oil
If it has a normal sump volume and a large (1-quart) filter, then 5 quarts (regardless of the dipstick) is about right. If it's a deep sump pan, then 5 quarts isn't enough, 7 is probably about right.
Whatever you do, you don't want the oil level high enough to get whipped into a foam by the rotating crank and rod journals.
69 C-10 SWB Fleetside 454/TH400 (For Sale)
http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12
70 El Camino 454 TH700
29 Model A 4-DR Sedan Deluxe
mnunn454 is offline   Reply With Quote
Old 08-28-2007, 09:48 PM   #9
bdmcgee
bdmcgee's Avatar
Re: Changing Oil
Thanks. . . . It only took 4. . . the only thing I can thnk of, and this is pretty basic, is that the dipstick isn't suppose to "seat" all the way down when checking the oil? My Valkyrie is like that. You only sit the stick on top, then check the oil. Is the GMC like that? Sorry for stupid questions...
Old 08-28-2007, 09:53 PM   #10
Sport/Truck
Sierra Grande Club
Re: Changing Oil
I think it should be seated when checking.
s/t
Old 08-28-2007, 10:20 PM   #11
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Re: Changing Oil
I think he meant.....did you replace the filter with a new one, or leave the old one on?
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 08-29-2007, 12:39 AM   #12
Farmstore34
Farmstore34's Avatar
Re: Changing Oil
I have the same situation on my '72 K20, 350 motor. I think the dipstick is out of a car. It shows full after only 4 qts. The last time I changed the oil I filled it with 5 qts, ran it, then remarked the dipstick with a punch.
Farmstore34 is offline   Reply With Quote
Old 08-29-2007, 12:45 AM   #13
BCOWANWHEELS
Re: Changing Oil
you better put 5 in it. i,ve never seen a bbc take 4 in 53 yrs of living
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 08-29-2007, 12:52 AM   #14
Select
Friday's Toy
Select's Avatar
Re: Changing Oil
How many quarts does a 454 take? I haven't changed mine yet due to it's consumption and blow by. First BBC owner here.....Mikey
68 C10, SWB Fleetside with a 454, Turbo 400 and 4.11 posi....Exxon/Mobil loves me.
2009 Jeep Rubicon
2011 Powerstroke FX4 (totaled)
71 C10, SWB Fleet with factory tilt
72 LWB C10, 350 700R4 with factory tilt
Select is offline   Reply With Quote
Old 08-29-2007, 01:49 AM   #15
BCOWANWHEELS
Re: Changing Oil
5 qts minimum, h/d trucks 7 qts, race pans up to 15 qts. my boat pan holds 12 qts.
Old 08-29-2007, 06:24 AM   #16
bdmcgee
bdmcgee's Avatar
Re: Changing Oil
Replaced old with new. . . . diffeent brand is all. I'm thinking it's the wrong dipstick. That makes the most sense.
Old 08-29-2007, 10:03 AM   #17
jerry moss
Born Psycho
jerry moss's Avatar
Re: Changing Oil
wrong dipstick or the pan was really smashed , it should take 5 qts minimum.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 08-29-2007, 12:42 PM   #18
Green Machine
Green Machine's Avatar
Re: Changing Oil
The long filters hold about a quart, the short ones only hold about 1/2 quart, that makes a little difference when trying to see if it is full enough. Likely need five quarts with a standard long filter.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 08-29-2007, 03:30 PM   #19
piecesparts
Parts and more parts
piecesparts's Avatar
Re: Changing Oil
You should have 4 quarts for the pan and 1 quart for the filter, unless it has a deep sump or an aftermarket pan that is made for more oil volume. Seat the dipstick to the tube and check it after the fill. I always fill my filter as much as I can before I mount it to make the dry start easier on the bearings. I don'know about your valkyrie, GM is not that creative in their processes.
Old 08-29-2007, 08:27 PM   #20
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Re: Changing Oil
How high was the engine when it dropped off the hoist onto the pan?
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
