Old 08-30-2007, 06:06 PM   #1
mcmlxix
Collector of Projects
mcmlxix's Avatar
Need pics of BBC throttle bracket...lost mine..need to find another
I took the motor out for the swap almost 2 yrs ago ... Now I cant find the bracket to attach the throttle linkage to the intake.. I have one off the small block but that don't fit... Does any one have some pics... it has the cable throttle, no the rod style....
thanks
Rich
1972 K5 Blazer CST Click HERE
Old 08-31-2007, 07:49 PM   #2
Classic Bowties
Always on the hunt...
Re: Need pics of BBC throttle bracket...lost mine..need to find another
thanks
Here are some pictures for you, this is on a very un-molested (when purchased) & original 72 highlander with the 402. The throttle bracket I think you are referring to was attached to the rear carb stud, not the intake. Also after comparing to another 71/72 BBC and 3 other SB trucks at my place, I have found them to all be using the same bracket-P/N 326564. Hope that helps, Cb
Classic Bowties is offline   Reply With Quote
