Old 08-29-2007, 11:48 PM   #1
wibilly
wibilly's Avatar
grill refinishing
was just wondering if there was a easier way to strip the anidized coating off a grill. i did a couple small spots where it was scrached by sanding and it really polishes up nice but i think it will take forever to do it all like that. will a chemical stripper remove the coating? any one have a secret they want to share?
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 08-30-2007, 12:35 AM   #2
combustion
Re: grill refinishing
nah man. even if there was. its better if you do it the Right way. you will thank your self later.
If it`s 3.73 ratio you will spint the wheel 100 times to the driveshaft`s 373 times.Or,if you`re lazy,you could just spin the wheel once and the driveshaft will spin 3.73 times.Or, 3 and 3/4 turns.And if you`re real lazy,I can sell you a tab for whatever ratio you want.
Or,you could read all the suggestions and try those.It`s been well explained,I think,already.
combustion is offline   Reply With Quote
Old 08-30-2007, 01:59 AM   #3
Dingfodgy
Lemme show you something!!
Dingfodgy's Avatar
Easy-Off! Yep, good ole fashioned sodium hydroxide oven cleaner. Spray it on let it set for a spell, but don't let it dry. Spray again if necessary to keep the surface wet for 10-15 minutes (do this on a cool-ish day in the shade if possible). Rinse off thoroughly. Start cuttin' and polishin'! Beware if there's any paint like in the cross bar or around the headlight....it'll take that off too- so you'll have to repaint.
'67 CST-10 LWB ("Crusty") SOLD
'67 GMC SWB ("Murdock")
2000 K1500 Suburban ("Betty")
'95 BMW 325i ("Joy")
Dingfodgy is offline   Reply With Quote
Old 08-30-2007, 02:06 AM   #4
RicksTrucks
RicksTrucks's Avatar
I picked up a bottle of stuff at a swap meet one time. Will see if I can find it and post the name. Suppose to take it right off. Of course, you have to keep it polished after you do.
68 Short Stepside C-10
69 SWB C-10
70 Flatbed C-20
70 LWB C-20 BB402
70 LWB C-10 CST
70 LWB C-10 CST
71 Short Stepside Cheyenne C-10
72 LWB C-10
72 Blazer 4x4 4spd
95 Jeep Cherokee 4x4
RicksTrucks is offline   Reply With Quote
Old 08-30-2007, 03:48 AM   #5
wibilly
wibilly's Avatar
yea i know i dont want to do this again i got 41/2 hours in haf of it and still don't have the shine i was hoping for but good enough for a work truck.how about clear coating it to protect it? i have seen it pealing on wheels and looks worse than it did before i started but theres no turning back now but it is 100 times better
Old 08-30-2007, 11:27 AM   #6
AH619
AH619's Avatar
Clearcoat It After You Polish It
72 2wd lwb cheyenne super youngest son.green/white
72 2wd lwb cheyenne super oldest son.green/white
71 4wd 3/4 cheyenne super frame off manderin
copper / white 4 inch lift. FINALLY DONE / SOLD
72 4WD SWB CHEYENNE BLUE/WHITE 388 AUTO
REMEMBER THE COPS NEVER THINK ITS AS FUNNY AS YOU DO. NORWOOD SURVIVOR
COPPERTONE BUILD THREAD/ http://www.67-72chevytrucks.com/vboa...d.php?t=259856
AH619 is offline   Reply With Quote
Old 08-31-2007, 04:29 PM   #7
mbgmike
Easy off was a a tried and true method years ago. It does not work as good like it used to.(like most good stuff). Do a search for anodizing and there are forums for that to. There are better methods. I tried the easy off a couple of years ago and it didn't do very good at all. I remove it now with a kit from Caswells that uses chromic acid and phosporic acid under an electrical charge. not real complicated and is easier.
mbgmike is offline   Reply With Quote
Old 08-31-2007, 04:50 PM   #8
49m
49m's Avatar
Mek will take it right of there. Thats what i use to remove clear coat from rims
49m is offline   Reply With Quote
Old 09-01-2007, 03:55 AM   #9
wibilly
wibilly's Avatar
1 aplication of the oven cleaner did not remove it but it sure made it sand off easier
Old 09-01-2007, 07:27 AM   #10
big blue 72
Gotta be CAREFUL with the MEK.
In Hazmat lingo it's call METHYL ETHYL DEATH!
big blue 72 is offline   Reply With Quote
Old 09-01-2007, 01:01 PM   #11
Dingfodgy
Dingfodgy's Avatar
Like Big Blue said....M.E.K. is nah-a$$-tee stuff, please use with extreme caution and do not let any of it get onto the ground or leave it laying around.
