Old 09-01-2007, 09:33 AM   #1
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Suggestions for cutting the wheel well.
I need suggestions on how to cut a 4.5" hole in the wheel wells.
I need the holes to run 4" ducts for a ram air box. I don't have a plasma cutter or anything fancy. I do have a lot of common garage tools. The ducts will have the intakes run from the bumper. I'm thinking of using a 4" straight duct then use flexible duct to make the connections. The first connection will from the bumber to the straight duct. The second from the top of stack to the air box.
The final look will like this setup.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 09-01-2007, 10:10 AM   #2
ont_guy_38
ont_guy_38's Avatar
Re: Suggestions for cutting the wheel well.
Use a jigsaw with a metal blade.thats about the easiest way with average tools.I have put sunroofs in using that method
ont_guy_38 is offline   Reply With Quote
Old 09-01-2007, 10:49 AM   #3
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
i dont think it a good idea the consept is great but the factory 4 inch hole the the front suport are what really were its bests.
Here y or at least i think y by puttinh in the well well u will suck up more road dubre/ dirt and if your diving and it rain ur going to suck up water. just a thought
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 09-01-2007, 11:07 AM   #4
gchemist
gchemist's Avatar
Which four inch hole?
Old 09-01-2007, 05:39 PM   #5
Restrorob
The One And Only !!!
Restrorob's Avatar
There should be two stamped knock-outs as below, I even have them on my 74 and plan on running mine to them.
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 09-01-2007, 07:05 PM   #6
gchemist
gchemist's Avatar
The core support on my truck is a 91. The holes are taken up by the side by side headlights. The bezels cover up everthing else. I might find something createive too.
Old 09-01-2007, 08:16 PM   #7
Restrorob
Restrorob's Avatar
Sorry, As many post I've seen about your truck I couldn't remember what year it is....
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 09-01-2007, 08:36 PM   #8
gchemist
gchemist's Avatar
A board user has suggested a NASCAR option. Turn the air box 180 and cut holes in the fire wall. Use the cowl for cold air intake. Sounds interesting but the brake booster poses a problem. I'll have to mount the air box and checkout the option.
Ram Air Box makes them too! The NASCAR style box.
http://www.ramairbox.com/models.html
This web page has pictures of several installations.
http://www.ramairbox.com/install.html
The setup would not cover up the RPM Aig Gap intake like the dual snorkel option.
Look at the 95 Chevy truck and the 99 Dakota. The configuration fits what I'm trying to do.
Old 09-01-2007, 11:06 PM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
This would be my choice-
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-01-2007, 11:08 PM   #10
slugish
Slugish
Red face Re: Suggestions for cutting the wheel well.
Ive got the ram air box on mine . Ihave the stock 84 radiater support frame , so Ive got mine into the holes already there. Do you or anybody know where you can get smooth 4 in. aluminum tubing . Ihave the dryer hose style & dont like the way it looks. you also can buy the smooth tubing from air inlet systems , but the only way it comes is black (aluminum just looks a lot beytter) & you cant paint it either . You would still have to use flexible couplings, if the smooth was available.
These systems are really eye catchers at shows , cruise ins etc. most all the hot cars & trucks have the old school open elements as you well know.
slugish is offline   Reply With Quote
Old 09-01-2007, 11:16 PM   #11
gchemist
gchemist's Avatar
Try a commercial A/C place. Or visit HomeDepot or Lowes. The smooth Al looks at lot better.
