Another VIN decode..
This is from a 72 GMC Jimmy supposively..will someone decode it for me..thanks
Dustin TKE182F (And then the rest of it) And the model number..KE15514 |
its all about the +6 inches
Re: Another VIN decode..
I have a couple assumptiond here, and I am not at the house to look at my books (i'm at the shop) but that resembles a chevy VIN quite a bit.
Rod is king on the GMC numbers. T GMC K 4X4 E V-8 of unspecified CID 1 1/2 ton 8 Blazer/Jimmy body 2 1972 F freemont Cali plant (and then the rest of it) |
KE15514
Model #'s on Jimmy nd Blazers is not really clear in the books I have but they pretty much break down like the trucks. K = 4x4 E = eight cyl 1 = gvw range - 1/2 ton 55 = an axle dimension from cab to rear axle... but being Jimmy they dont really list the number that it represents in the GMC line, but I believe it represents 30 inches. 14 = Jimmy body style Longhorn Man got the vin decode correct.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
Thanks Longhorn Man and Rod.
Actually, the "F" in the vin means it was made in Flint. I beileve Fremont it represented with a "Z".
Evan
70 Blazer 4x4 305/sm465/np205 80 Buick LeSabre Limited 72 Honda CB350F 77 Honda Cb750K 00 Ducati Monster M900ie |
good call, you are absolutly right too.
#7 | |
Do the Dew!
Here is a link that you can enter yours at: http://www.americanclassic.com/paint_test.asp My vin# is CE148Z17#### I love to see vin decoding here, helps for questions presented by others. ![]() Last edited by mtndewmaniac66; 09-02-2007 at 01:15 PM. Reason: found link to vin decoding. |
That site is kinda funny, it doesn't recognise a 3 as a one ton, it lists everything outta order so people will try to decode wayoutta wack, and the said my truck was the 160293rd one made... when it is the 60293rd.
http://67-72chevytrucks.com/Chevyear.html is the best one I have seen... it is missing the '72 only added digit, and it doesn't include codes for burbs, panels, cab/chassis, or blasers... but the stuff it has, is dead on right. |
