Old 08-25-2007, 01:42 PM   #1
59gmc
Where Are The Key Numbers?
Hi can anyone tell me where I can find the door key number for my 59 GMC stepside? The ignition key fits in the door lock but will not turn and so I thought if I could find what the key number is for the doors then it hopefully should be fairly easy to get another key cut.
Many thanks
59gmc is offline   Reply With Quote
Old 08-25-2007, 06:19 PM   #2
CAL 58 GMC
CAL 58 GMC's Avatar
Re: Where Are The Key Numbers?
A good Lock Smith should be able to make you a key without a key number. I would give your local Lock Smith a call. Our you could buy a new ignition and lock key set. Here's a few links. http://www.lmctruck.com/icatalog/ca/0065.asp or http://www.brotherstrucks.com/prodin...number=JDLGB59
CAL 58 GMC is offline   Reply With Quote
Old 08-28-2007, 02:35 PM   #3
59gmc
Many thanks.
I did take the barrel out of the handle and the locksmith was able to find the correct cuts required for the key and all for only £3.00.
Thanks again
Old 08-28-2007, 11:37 PM   #4
CAL 58 GMC
CAL 58 GMC's Avatar
How much would £3.00 be on the other side of the pond?
Old 09-01-2007, 11:12 PM   #5
dh81k30
Junior Member
dh81k30's Avatar
real good deal > approx. $6.05 US
Have fun, Don
dh81k30 is offline   Reply With Quote
Old 09-02-2007, 10:55 PM   #6
CAL 58 GMC
CAL 58 GMC's Avatar
Not a bad price.
