Old 09-01-2007, 10:41 PM   #1
dan42
dan42's Avatar
2/4 drop ride quality
I want to drop my '67 with a drop kit that has the shorter coil springs (2" in front and 4" in back) and I was wondering if anybody has done this and noticed a harsher ride, or will it ride about the same. I'm gonna keep the drums for now so I'm not gonna use the drop spindles in the front. Thanks for your input in advance.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 09-01-2007, 11:27 PM   #2
70c10
67-72 Addict!
70c10's Avatar
Re: 2/4 drop ride quality
It will ride the same and might handle even better lowered. Mine did!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 09-01-2007, 11:32 PM   #3
dave2953
Dave's not here, man
dave2953's Avatar
Mine rides really nice with my 2.5/5" drop.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 09-02-2007, 12:39 AM   #4
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
You will find a difference of opinion at to which method is better, but apparently not about the quality of the ride. My drop is with spindles, but that was done to gain disc brakes. There have been discussions about alignment when using shorter springs, but I don't have a dog in that fight.
I am of the opinion that having good quality springs is one of the most important factors in gaining a good ride and drive. Good springs and good shocks are must-haves.
Member Nr. 2770
Old 09-02-2007, 01:57 AM   #5
zerwar
Sgt. Z
zerwar's Avatar
mine rides much nicer.........guessing the brand new lowering springs and shocks made a huge difference. Also when I bought the truck, I greased ever grease zirk that I could find......stopped all the loud squeeks as well. dont thing the previous owner new how to do that because they were all dry.
1967 Chevy SWB
1966 Malibu SS Convertible 355/420hp
700r4 and 373's with eaton posi
To deny our own impulses, is to deny the very thing that makes us human~The Matrix
zerwar is offline   Reply With Quote
Old 09-02-2007, 01:59 AM   #6
Jayss109
Active Member
Jayss109's Avatar
I did a 2/4 drop with ECE springs on my LWB. Kinda hard to say, since I rebuilt the rest of my OLD front end at the time. It seems a little stiffer, but much more responsive @ the same time. Recently I have notived that it has gotten a little sloppy.... more body roll when taking corners or making quick lane changes. Gotta get underneith and see whats going on.
I put in small block rated springs in the front, even though I run a big caddy motor.
Jason
Cadillac Powered
Jayss109 is offline   Reply With Quote
Old 09-02-2007, 09:01 AM   #7
Joe67
67 is sold
Chances are your existing springs are worn out, any new springs will improve the feel and ride a good deal.
As stated above you should see better handling as well - go for it
Don't forget the adjustable panhard bar for the rear as well as the rear shock relocator kit and new shocks
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 09-02-2007, 10:33 AM   #8
cdowns
cdowns's Avatar
you really should put new balljoints tyrod end and generally rebuild the front end in the back new bushings in the trailing arms and new shocks with relocaters at the rear as well as swaybars front and rear will all go a long way in resulting in a much better ride quality
Old 09-02-2007, 01:21 PM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
If you use spindles to lower the front, the ride will not change "unless" you change the shocks at the same time. If you go with springs, the ride will be firmer, but not harsh "unless" you change the shocks too.
As you can see, it not always one component that changes the ride so much as it is a combination of parts replaced together. Spindles do not change your ride. Lowering springs will only make a mild change and usually for the better. Add too stiff of a shock, or even worse one that's too long and bottoms out will have a very adverse affect on your ride quality.
Something you didn't mention is what tires you are going with. Low profile tires have a huge impact on ride quality. Regardless of whether its a 15" or a 22" the lower the profile, the harsher the ride....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-02-2007, 05:16 PM   #10
Shane
Shane's Avatar
love the new avatar N2.
Shane is offline   Reply With Quote
Old 09-02-2007, 05:43 PM   #11
cdowns
cdowns's Avatar
thats a real good point about the tires an inch or 2 wider on rims also makes a big difference
Old 09-02-2007, 09:37 PM   #12
N2TRUX
Happy to be here
N2TRUX's Avatar
Thanks Shane. 75silverstep made that for me when he was bored one day.
Here's the full size version of it....
Articles-
"Refining Sierra"
Old 09-03-2007, 12:56 AM   #13
Shane
Shane's Avatar
full size is even better! kick ass!
