Old 09-04-2007, 11:17 AM   #1
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
Getting ART arms - what spindle?
Hey, I've got bags front and rear and am going to be getting ART upper/lwr arms. I will be getting new drop spindles so my question is which should I get and which will work on my setup? I have a 6-lug disc conversion up front. Anything particular I need to know before I order? Also, what is your preference and why: Belltech 3" or ECE? Is there really much difference between the 3" and the 2-1/2 from ECE?
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 09-04-2007, 11:32 AM   #2
SCOTI
SCOTI's Avatar
Re: Getting ART arms - what spindle?
Get the correct spindle for your 6-lug brake conversion. I believe they're based on 73-up spindles but it's better to verify that through the manufacturer. FWIW, it's easier to find stuff for 73~87's.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-04-2007, 04:40 PM   #3
67Fleet
67Fleet's Avatar
That's why I posed the question. The PO did all the conversions and I have no idea how to tell what I have, therefore no idea on what to replace with. Can you offer any additional info? It's always difficult dealing with someone else's mess.
-Bret
Old 09-04-2007, 04:43 PM   #4
SCOTI
SCOTI's Avatar
Ahhhh.... I see said the blind man.
Call one of the vendors. See if they can confirm the 6-lug kits are basically re-drilled 5-lug rotors & if they're 73 & later or????
Other than that, the easiest way might be to get an outer tie-rod for 71-72 & 73-up to test fit on your current spindle. Which ever tie-rod fits should tell you what you need to know.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-04-2007, 04:47 PM   #5
gringoloco
A guy with a truck
gringoloco's Avatar
Measure the thickness of the rotor- if it's 1.25", use the Belltechs. The 6-lug conversion rotors are just HD blanks drilled for 6-lug.
They are not a full 3" from what I gather, but they are more than a 2.5" ECE. The 73-87 parts are also cheaper/more readily available. Can't go wrong with either for quality. I've got Belltech on the truck and ECE on the Blazer.
Since you're swapping everything- use the Belltechs- my .02.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 09-05-2007, 02:33 PM   #6
67Fleet
67Fleet's Avatar
thanks guys, I'll measure tonight and go from there. I'll post up some pics with my new digicam also to see if it helps you guys to see what I have.
-Bret
Old 09-06-2007, 06:11 PM   #7
67Fleet
67Fleet's Avatar
gringo, it is 1-1/4" wide. What do you mean by "HD blanks"?
-Bret
Old 09-06-2007, 06:45 PM   #8
gringoloco
A guy with a truck
gringoloco's Avatar
'Heavy Duty' These are the rotors used on 71-80 or so, then GM made them optional and introduced a light duty 1" thick rotor. Most aftermarket kits are based around the HDs- they just buy them blank and machine for 6-lug instead of 5. If this is the case with your set-up, the Belltech 3" will work.
-Chris
-Chris
Old 09-06-2007, 07:50 PM   #9
67Fleet
67Fleet's Avatar
ok, so I can order the Belltech's for the 73-87 trucks and balljoints for same? Do I order arms for 73-87 also then? It's a lot of money to drop all at once so I want to make sure I'm getting the right stuff.
-Bret
Old 09-07-2007, 12:38 AM   #10
gringoloco
A guy with a truck
gringoloco's Avatar
Yep. The ART arms come loaded(cross-shafts, ball joints) so you won't need joints, but you will need inner/outer tie rods.
Do you have drop spindles now? What kit is it?
-Chris
Old 09-07-2007, 09:22 AM   #11
67Fleet
67Fleet's Avatar
yeah, but have no idea what brand they are. There are no markings on them that I can see.
-Bret
