HELP! Problem with rear leaf conversion kit?
HELP! I ordered this kit from CPP:
http://www.classicperform.com/Store/...ks/5559RLK.htm We have the brackets on the driver's side, and went to test fit the spring before drilling the rest of the holes... and the spring is WAY too short. Did we do something wrong? Did they send us the wrong parts? Is it my truck that's the problem???? ![]() ![]() ![]()
1956 Chevrolet 1500 Task Force 2002 Texas Aggie Project Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=212633 |
Re: HELP! Problem with rear leaf conversion kit?
I haven't installed that kit before but........try taking the front perch and moving it to the other side........use the notch in the plate and put it over the rear "stamping" on the frame..........looks like it might give you the spacing you need,,,,
We thought to try that, but if you do you lose the ability to "reuse" the top holes from the original mount. All the instructions --- the crappy ones that come with the kit and the magazine article installing it --- specifically say "reuse" the top two holes on each bracket...
Ttt
I would measure the length of the leaf and call the company and ask them how long the leaf should be and that you think they sold you the wrong one.
Lotus Current Rides/Projects 1955.5 Chevy shortbed truck 1952 Chevy Coupe Deluxe car |
I think it is the wrong spring.
Your seem to be installed in the correct place, but the middle of the spring is not even under the place where the axle used to be. I would call cpp. Btw, the instructions that came with my IFS, where as good as yours ....
1955 2nd series 3100 Pickup, MustangII IFS, Ford 9" with 4 link, 4 wheel wilwood disc brakes, 383 Callaway supernatural, 4L60E ![]() 'All people dream, but not equally. Those who dream by night in the dusty recesses of their mind wake in the day to find that it was vanity. But the dreamers of the day are dangerous people, for they may act their dream with open eyes to make it possible.' |
Hollister Road Co.
I second the motion, they must have sent you the wrong spring.
Looks like you have your brackets swapped over from the CPP tech sheet page:
http://www.classicperform.com/tech_a...ipYourRear.htm Look closely at pictures 14 and 15. |
Hollister Road Co.
Good eye robin58, I enlarged the pictures and they are on the wring sides. The bracket cut out goes over the rearward out dent on the frame not the front out dent in the frame. The fatter part of the bracket should be directly under the ebrake cable bracket with the thinner part facing toward the back of the frame. Picture eleven shows it if you can blow it up.
God bless y'all. You have added years to me life I thought taken from me. Wow. My faith in classic trucks is restored.
THANK YOU.
#11 | |
I am as dense as a 2x4. Thanks, prostreeter. We're back on track (whatever that is).
Hollister Road Co.
#15 |
Installation could have been so easy and boring.
A big thank you to the manufacturers for their thrilling installation guides......
#16 |
Just think of all the beer you wouldn't have consumed if the installation had gone smoothly
#17 |
I haven`t seen it from this point of view.......
#18 |
A-m-e-n.
#19 |
Dos this kit ride on top of the housing like stock or under it like a "flip kit" set up? If it rides on top, would the truck be too low if you "fliped it"?
Anthony |
| Bookmarks |
