Old 09-05-2007, 01:26 AM   #1
JustinR
JustinR's Avatar
1 ton axles
I have been looking for a newer 4x4 dually, to covert to 67-72 body style and use a 12' flat deck. I recently found this 1990 Chevrolet 3x3 dually for sale. It looks to me like it is a GM corporate 14 bolt in the rear and Dana 60 in the front. They seem to be fairly expensive if you can even find a set for sale.
I just want to make sure those are indeed the axles I think they are. So let me know what you think.
Thanks a lot!
1971 Chevy Crewcab cummins diesel 4x4
1970 Chevelle
1967 Chevy c/30
JustinR is offline   Reply With Quote
Old 09-05-2007, 06:54 AM   #2
Blazer1970
Blazer1970's Avatar
Re: 1 ton axles
Yup, front 60 rear 14 bolt. That truck would be a good starting point for a build. Could also have a 454 and/or TH400.
Blazer1970 is offline   Reply With Quote
Old 09-05-2007, 11:44 AM   #3
Burt4x4
Burt4x4's Avatar
Re: 1 ton axles
yup D60/14FF WIDE
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 09-05-2007, 03:50 PM   #4
1969 GMC
1969 GMC's Avatar
Re: 1 ton axles
Originally Posted by Burt4x4 View Post
yup D60/14FF WIDE
That truck should have a C&C rear axle, which is narrower.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 09-07-2007, 06:41 AM   #5
Re: 1 ton axles
Just so you know.If the tube size doesn`t give them away,look at the short side and see that there`s one u-bolt to the outside and the inner is bolts into the top of housing.A sign of the beefiness.
