disc brake master cylinder
Finishing up a 4x4 disc brake conversion on my 67, can I use my non dics brake master cylinder, or do I need to change it. Thanks
65 tripower conv 4spd gto, 66gto, 67 gto 65 lemans conv 4spd 69 firebird conv. 67 c20 4x4 |
Re: disc brake master cylinder
Change it.
yeah, change it. Disc brakes require more fluid flow than drums.
Also need to change the prop valve to a disc/disc valve or install an adjustable one
Mike
Mike Redpath |
![]() Join Date: Dec 1999
The drum master holds more residual pressure than the disc unit does. Found out the hard way. Had a drum master on my '71 bled it out and couldn't turn the rotor because of the difference in the residual pressure.
Smitty '71 Short Fleetside Spring Valley, Ca. |
