hey guys, on my 383 i bought this summer the water pump bracket bolts onto the water pump off of on of the water pump bolts, (doesnt look right to me) the exhaust is 63-64 corvette ram horns, so you have to have the "f" bracket on that, and then the long arm comes up and bolts onto the alt. anyone have pics of somthing like this?
1971 k5 blazer 80k mike survivor 1972 3/4 ton 4wd Cummins 12v 1967 swb 2wd 427bbc 1968 4wd shortbox 1971 Cheyenne swb k10 unrestored 1971 Cheyenne super 40k 402bb survivor 1967 Chevy k10 (first truck) 1968 L78 camaro survivor 18k miles 1969 z28 survivor 60k miles 1969 z28 survivor 39k miles 1969 z28 rs survivor 80k miles |
Matt,
I am confused, do you mean Altenator bracket? Is this a short water pump or long water pump? Jim |
brackets
haha, omg im retarded i knew i did somthing wrong! water pump bracket.. hahaha well yeah i meant alt. brackets i have a short water pump sorry guys
http://www.alangrovecomponents.com/ they have the best brkts ive found
Jim
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
Matt,
What you describe sounds like the setup for the small block car alternator brackets. On the left side, the exhaust manifold has an ear cast into it with threads. The bottom pivot bolt goes through a bracket and screws into the manifold. The adjustment bracket fastens to the water pump bolt on some years or to the intake manifold and to the alternator. Corvettes had a similar setup. My 65 Impala has the setup and it works well. Here is a pic of my Impala, It has the adjusment bracket going to the manifold which has the threaded hole for the bracket. Jim |
would you happen to have any more pics of that impala engine? ok i think what you described is pretty much what i have on my truck.. thanks guys
Matt,
I can take another pic over the weekend and post it Monday if you like. Jim |
yeah thatd be great. thanks a lot
