07-26-2007, 05:10 PM | #1 |
Non power brake master cyl
I have a ? about what master cylinder to use. I am going to go with non power brakes,and am wondering what master cylinder to use. Any help?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
07-26-2007, 05:57 PM | #2 |
Re: Non power brake master cyl
If you have drums all the way around you can just use a manual brake master cylinder. For safety you would use a two chamber equal size master. Most manual GM masters are kind of universal. They do not cost much.The single chamber ones are pretty useless and not very safe.
07-26-2007, 06:00 PM | #3 |
1962 C-10
Order one for a 72 truck that has discs in front and drums and back, non-power.
Joseph Chavez "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
07-26-2007, 06:05 PM | #4 |
Yeah we sell those to. Would not really hurt. Mainly its the bore size. The Larger front reservoir really won't matter. Keep the bore size 1"
07-26-2007, 06:15 PM | #5 |
I should have mentioned Im installing spindles/discs. Thanks
07-26-2007, 06:17 PM | #6 |
Yeah makes a difference
07-26-2007, 08:51 PM | #7 |
Does two-chambers mean you have to have two failures before you have no brakes?
07-27-2007, 01:25 AM | #8 |
kinda, it has a individual chamber for each set of brake, one for the front and another for the rear. thats y they have 2 lines going out of the mc. that way if one fails u still have the other
07-27-2007, 11:22 AM | #9 |
I talked to John (chiefrocka) before about this, and here is the master cylinder that he said would work. Cheap, for non power brakes, and it bolts right up supposedly!
http://www.partsamerica.com/productd...pe=230&PTSet=A |
07-29-2007, 05:45 AM | #10 |
and a few others
you know if the push rod needed to be trimmed or modified?
Bill US Army Vet -193rd Infantry BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
07-29-2007, 08:52 AM | #11 |
so mine its a single chamber, than for what i have read its much better to go for the double chamber?
its there other modification need it to install one of this?
1966 chevy c-20 truck " La Chata " under construccion |
08-30-2007, 09:57 PM | #12 |
Yep, you have to split the front and rear lines into 2 circuits.
08-31-2007, 05:49 AM | #13 |
Hollister, CA.
Hey Sal...I have a master off of a 76-77 Full Size GM car....Cutless to be exact....front disc and rear drum.
I bought it new for the car years ago..took it off when the car blew up. Been sitting ever since. You can have it if you think it will work. Let me make sure I still have it on my shelf...
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
08-31-2007, 11:12 AM | #14 |
Thanks John I picked one off of a 72 pu. Hey I found the radio delete It's yours Monster Garage style...... freebie zilch nada zero.
09-04-2007, 11:12 PM | #15 |
any pics of the split of the brake lines? I need this upgrade....
09-05-2007, 10:30 PM | #16 |
Why no power brakes with disc brakes? It takes more effort to stop disc brakes because they are not self-energizing like drums.
09-05-2007, 11:10 PM | #17 | |
I guess non power brakes are better then no power drums.
