What other fuel tanks have been used?
What factory tank has been used out back in place of the stock tank? Looking for something like a late tahoe with pump and sender already installed to feed the LT-1. Trying not to break the bank with a new Stainless one yet.
Mike
Mike Redpath |
Re: What other fuel tanks have been used?
Some have used later model blazer tanks with internal pumps but their really large, like 30 gallons or something close to that.
I looked into one, actually had it sitting under the blazer at the shop and said to myself, no freakin' way am I willing to do what it takes to make it fit. Maybe an actual Tahoe tank might be different. I ended up going with a fuel cell. Was less than 35% more than a full factory tank/pump/pieces. Yeah it was more but in the end, the better result. Next build will get one too. |
which fuel cell did you use? Summit has a poly tank that seems close.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 09-02-2007 at 08:16 AM. |
#4 | |
I had another board member that goes by the name of 'Fuel Cell Guy' build me one that gave me the ground clearance I was needing. Awesome work at a fair price. Built in baffles too. |
A guy with a truck
Fuelcellguy still ends up being about $600 by the time it's all said and done.
The Summit cell will work, but then you still need a pump. Tanks inc. has these for ~$200, plus mounting straps puts you at around $400. I bought a surplus late Blazer tank that I think I will have sectioned by my local radiator shop and use the '87-up sending unit with a Walbro pump.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
Cochino_Racing_909
Question for ya guys. I have a 37 gal tank I got on a blazer I bought it has a pancake size dent in it in the bottom Is it possible to have this taken out with out it exploding or damaging the tank? Oh yea sorry If I seemed Like I HIjacked this thread but it just a question pertaining to Gas tanks
Tim Christian (site vendor) sent me to these guys...
http://www.nolimit.net/ $459 http://www.nolimit.net/prodinfo.asp?number=B%2DTNK
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
#8 | |
True, actually a little bit more than that after shipping BUT he did it my way. Worked with me alot discussing the demensions I was looking for, well worth the cost IMO. There are always places to find it for less and ways of doing it cheaper, the choices are out there for sure. |
18 gallons and it allowed me to do this.
I was considering a 26 gal tahoe tank. I measured the big 30+ gal tank and it is just too big.
The No Limit tank doesn't have an intake pump so it is no better than a stock tank. Fuel Cell Guy has dropped off the earth I think and for that money I would rather buy a new Rick's Hot Rod tank and pump setup. I haven't considered a fuel cell, looking for something for factory appearing. Mike
Mike Redpath |
Tahoe Tank??? What years?
Thanks |
I have to do some more measuring but something like '95 and up
Mike
Mike Redpath Last edited by Musclerodz; 09-04-2007 at 06:11 PM. |
Oh..never mind....
I went through this whole thing when I was considering using the Vortec injection system from a 1999 Tahoe. The stock tank is too long and an odd shape. Most of all the tanks that I considered were to big, or the shape would have made the installation difficult. I looked at van, S-10, Tahoe, and newer Blazer tanks. It ended up being the deal breaker for me. The only option that fit the needs that I wanted was a custom tank like the one VT had made. One thing I was cautioned about was to make sure that the tank was built from someone that had a DOT certification. The point made to me was, if you were ever involved in a crash where the tank ruptured with a non-certified tank and someone was hurt as a result, then you would be liable. In the end, I am going with a carb to get it going for less money for now.
1972 Blazer -6 inch lift -35 inch BFG A/T's Turbo 350 NP-205 454 BB (for now) MORE TO COME !!!!!! Now going to 2WD!!!!! Sold. ![]() ![]() ![]() I got it back after 22 years and did not even know it !!! THE STORY HERE Project Low Down Dirty Rat |
#15 |
I have used Blazer tanks in LWB trucks, but im sure withe a liitle work they will fit a Blazer. www.spectrapremium.com has all the tanks and pump listings and all sizes on there website. My last tank I used was the GM 15. Fit perfect.
Darren
67- 72 Parts collecter |
#16 | |
A guy with a truck
#17 |
Stock tanks w/aftermarket pumps should work w/Vortec. electric pumps are made to push, not pull, fuel, and that's why they are in the tank. I've got another Q: those that have put fuel doors in front of the rear wheels (TonyP?)- what tank and plumbing did you use?
'72 K5, known as 'the Fox.' |
#18 |
A guy with a truck
I've been searching for a while for a solution to this problem and may have come up with one:
The 87-90 Jeep wrangler 2.5 4cyl EFI tank uses a GM fuel sender. The GM in tank pump or an equivalent Walbro should swap right in place of the stock pump. Its dimensions are 25.25"W x 18.25"L x 10.75"H. Pros: Correct 0-90ohm sender Pump compatibility Tanks readily available aftermarket- steel or poly- and cheap Cons: Only 15 Gallons Sending unit is nearly unavailable- I found one place that has them for $175! Will need an upper strap because tank will not snug up against the frame rails- too narrow May have to move rear crossmember a few inches back. I have not measured yet Good thing about the sending unit- the '87 Blazer 25 gallon tank is the same depth so it should be a bolt-in affair if you can't find the Jeep one cheap. The Blazer sender can be had all day long for ~$60. So- Jeep tank($80), Blazer sender($60), Walbro pump($100)= `$250 all brand new parts. If you can find the Jeep tank and the Tahoe pump in the yard you could potentially do this for less than $100! Now someone just has to guinea pig this...
#19 |
'87 Blazer should be an FI tank, so I will take a very close look at it. The 15 gal on the Jeep tank is a deal breaker for me. It has too have the same or more than the original
Mike
Mike Redpath |
