09-06-2007, 12:58 PM | #1 |
Ram Horn Clearance--
Has anyone seen swept back style ram horn exhaust manifolds that have a 2 1/2” outlet? I can only find this style in a 2” outlet. I have seen 2 1/2” outlet manifolds but the all exit straight down and I’m worried this will make it harder to keep the rest of the exhaust off of the ground. I want to be able to drop my blazer on the LCAs and still keep my exhaust off of the ground. Is this possible with the straight down exiting manifolds? I have shorty style ceramic coated Hedman’s currently but I had to dimple them the get them to “fit” and I don’t like that.
If anyone needs an example of the swept back style I can post a picture once I find it.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
09-06-2007, 01:17 PM | #2 |
Msgt USAF Ret
Re: Ram Horn Clearance--
This what you are talking about? It's upside down in the picture.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
09-06-2007, 03:15 PM | #3 |
Yes, thats it. I'm looking for that with a 2 1/2" outlet. Does it exist?
09-06-2007, 03:22 PM | #4 |
Yep......
Evil Bay -> :O(
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps. 68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread |
09-06-2007, 03:37 PM | #5 | |
Sierra Grande Club
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
09-06-2007, 03:46 PM | #6 |
Believe me, I've been on eBay. I can't find them. At this point I just want to know if they exist so I can continue my search before I settle for something different.
09-06-2007, 05:59 PM | #7 |
I'll find some links for you !
09-06-2007, 07:13 PM | #8 |
pickmup ( frank ) has some vette 2 1/2" manifolds that are nice. there straight down though. hi-quality and great price too.
bob
I BELIEVE IN JOHN 3:16 |
09-06-2007, 07:18 PM | #9 |
Insert Title Here
im pretty sure the ones that kick back only came in 2", so I wouldnt look to hard
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
09-06-2007, 07:27 PM | #10 |
i never seen any 2 1/2" that were not straight down[corvette ones}i don't think you will find swept back ones if you do i wanna see them!
common sense isn't so common anymore |
09-06-2007, 07:45 PM | #11 | |
Does anyone have the straight down style on a bagged truck? Should I worry about clearance or will I have enough room to bend 2 1/2" pipe before it hangs lower than my LCAs?
09-06-2007, 08:04 PM | #12 |
Insert Title Here
some good pics and info here... I bought the set, but have yet to install it
http://67-72chevytrucks.com/vboard/s...ighlight=vette
09-06-2007, 08:27 PM | #13 | |
09-06-2007, 08:45 PM | #14 |
You can get a ( GOOD) muffler shop to run the exhaust. If you run a mini-starter, that will solve alot of the clearence problems. I had those manifolds on a truck that was lowered 4 1/2 and 6 3/4 in the rear. I know that's not bags. I used a 90 model Chevy truck starter,but the mini would give you quite a bit more room for the bend you need.
09-06-2007, 09:22 PM | #15 |
Always on the hunt...
All of the original 2-1/2" gm p/n 3846559 & p/n 3747042 ram horn manifolds dump straight down and were standard equip. on all 62-65 high performance chevy small blocks with fueler heads and a rating of 300hp or more, they were found on vetts, impalas and a few chevelles. Cb
