Old 05-11-2002, 11:22 PM   #1
Jesse 67 c-10
Jesse 67 c-10's Avatar
Post Electric fans
while I was at the yard getting my driveshaft I also got a couple electric fans from a 90 chev lumina. They are about 13" across so they should just fit on my rad. I'm hopeing they provide enough air flow, they almost lift themselves up when I test them but I guess I'll find out when I get them hooked up. What I'm wondering is how to wire them up? can I get a thermo switch from a lumina and then a relay or....? I know some people have done this before, anyone have a wiring diagram from an aftermarket setup or something, this would be a great help, Thanks!
Jesse
Near Saskatoon, Saskatchewan, Canada. 67 c-10, Long fleet, Newly swapped front disks, 5 lug rear end, 327 v-8 with Vortech heads, edlbrock performer rpm air gap manifold, 1406 carb and comp XE 256 cam. Backed by a getrag 5 speed and 1 piece driveshaft. Finnally running, almost driving! www.geocities.com/chevy67jesse
Edmonton, Alberta, 67 c-10, Long fleet, front disks, 5 lug rear end, 327 with Vortechs, edlbrock manifold, comp cams XE 256, 600cfm carb. Backed by a getrag 5 speed and 1 piece driveshaft.
1993 Dihatsu Hijet Jumbo cab 4x4, currently converting to battery electric power.
Jesse 67 c-10 is offline   Reply With Quote
Old 05-12-2002, 01:56 AM   #2
Mudder
Mudder's Avatar
Post
I think its Oreily's has a sesor that goes into the neck for the themo'. Think u can set it to were u want them to kick on.
67 stepside 4x4 Owensville MO mudder67@hotmail.com
Mudder is offline   Reply With Quote
Old 05-12-2002, 09:06 AM   #3
Andy4639
Old member
Andy4639's Avatar
Cool
Are you planning to just run the electric are run them with the mechanical one? I found a small electric a while back and hooked it up to come on when I have the ac on only to help cool it down. What I did was run the on/off wire from the compressor, the switch under the inside of the cab that the cable operates when you turn the ac on, to relay then have battery hot to fan and ground.
I wouldn't use the temp. sending unit from the lumina it would be to hot I would think for your truck. It's computer rized yours isn't. I would go with a aftermarket set up.
Andy
71's Are for ever!!! or 67,68,69,70,72
71,factory tach,tilt for straight drive,gauges,ac,speed warning,clock,305 HO TPI with 700-R4, lowered 2" & 3" ,and 17" Chrome Stealth wheels, Pioneer reciever,100 watt amp, 6 disc changer, 2-10" subs (behind seat) 2-6x9 in doors, 2-3ways mounted under seat, and 2 tweaters on door panels
www.geocities.com/chevy71tpi/main.html
www.picturetrail.com/Andy4639
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 05-14-2002, 12:47 PM   #4
Jesse 67 c-10
Post
Thanks for the help, I got 2 to use without a mechanical fan. I'll look around and see if I can find out about that sensor.
Old 05-14-2002, 01:15 PM   #5
Shane
Shane's Avatar
Post
Painless Wiring offers an aftermarket electronic temperature switch (adj. thermostat). It it adjustable to the desired temp. I know a lot of guys in the street rod circles run two fans. They wire one to run constantly and then wire the second one to come on at a desired temp and then turn off at a lower desired temp.
Hope this helps.....
Keep On Truckin'
Shane
Athens, Alabama
[This message has been edited by Shane (edited May 14, 2002).]
Shane is offline   Reply With Quote
Old 05-14-2002, 01:24 PM   #6
bigvinnie
bigvinnie's Avatar
Post
You can get a thermostat kit outa the jegs or summit catalogs that will allow you to dial in when the fans operate... mine sits on the radiator core but I think you can get one that taps into the thermostat housing as well....
I would think the hard part is gonna be coming up with a decent way to mount your fans... I got a Flexalite Black Magic fan from summit that came with its own shroud and it works great... it's a puller type, replaced the belt-driven one. Good Luck.
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA
http://www.ixpres.com/vlusardi/chevtrk.htm
72 Stepside Project
bigvinnie is offline   Reply With Quote
Old 05-14-2002, 01:32 PM   #7
busterwivell
Post
If you do that, Vinnie, then you eliminate not only the mechanical fan but the big bulky factory schroud, too. Does it cool well? Wonder if I could do that on my 402 and be able to run the A/C in Tucson heat?
56 Studebaker 2 dr Wagon
66 Chevelle 2 dr 4 speed
71 C30 Longhorn
86 Monte Carlo SS
96 Tahoe
Bill - Tucson, AZ
47 Chevrolet 2 dr sedan
56 Chevrolet 210 2 dr sedan
66 Chevrolet Malibu 2 dr 4 speed
71 Chevrolet C30 Longhorn
86 Chevrolet Monte Carlo SS (Sold)
01 Chevrolet Tahoe
IM - BUSTERWIVE@aol.com
busterwivell is offline   Reply With Quote
Old 05-14-2002, 01:56 PM   #8
Jesse 67 c-10
Post
That sounds good for the switch, will any old parts store relay do? for 2 fans what amperage do you think they draw? Probably 14 guage wire should be enough for the fans?
I should be able to figure out the mounting though, I've made lots of things on my truck! Thanks
Jesse
Old 05-14-2002, 02:01 PM   #9
bigvinnie
bigvinnie's Avatar
Post
they claim it's good for engines up to 300 hp, which is about where mine is, plus I'm running A/C, and also have a trans cooler, so it has to pull through 3 radiators basically.... no problems.
I actually mounted the fan in the stock shroud, so it still looks kinda stock, except for the thermostat adjustment knob on the top...
I'm very happy with it, stays cool in stop n go traffic on a hot day with the A/C on... there's also a 2 fan setup that comes in its own shroud available that pulls more air, not sure how much fan your big block would need.... you can check it all out at www.summitracing.com
72 Stepside Project
Old 05-14-2002, 02:04 PM   #10
busterwivell
Post
Thanks, Vinny
Bill - Tucson, AZ
01 Chevrolet Tahoe
Old 05-14-2002, 02:11 PM   #11
bigvinnie
bigvinnie's Avatar
Post
just looking at the 2 fan setup on the summit site, it draws 18 amps... 12 or 14 ga. should be ok.... get a heavy duty relay also, can't hurt.... check out www.summitracing.com and look up this part number.... DER-16759.... it's a relay with a probe for the radiator fins... it's what I'm using and I haven't had any problems
72 Stepside Project
