Old 09-08-2007, 12:30 PM   #1
SLIMJIM
Help needed......!
Just had the gas tank dropped, cleaned and replaced. The sending unit worked perfectly before and now reads WAAAY past full. The needle will move a little when the ignition is turned on, but its still squirrely.
If someone can post some info I'd 'preciate it.
By the way, I tried search, but it isnt working.......Thanks.
SLIMJIM
1970 Chevrolet Blazer 2 wheel drive - SOLD
SLIMJIM is offline   Reply With Quote
Old 09-08-2007, 12:33 PM   #2
jhow66
jhow66's Avatar
Re: Help needed......!
Make sure your tank is grounded.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 09-08-2007, 12:37 PM   #3
SLIMJIM
Thanks jhow. I had a shop do this for me because of not having another person to help me. They said they hooked it ll back up, but....you never know. I will mention it when I take it in monday. Thanks again.
SLIMJIM
Old 09-09-2007, 12:38 PM   #4
EAST SIDE LOW LIFE
EAST SIDE LOW LIFE's Avatar
I would also look at the sending unit as the possible fault. On the unit there is a small flat lenfth of wire that can become corroded and cause the gauge to swing to the right to the bottom of the gauge. I changed my sender unit in my 70' and cured the problem.
esll.
Tomorrow is for doing today's stuff.
This truck has just the right amount of energy for me!
Author: Warren Lake .... (member)
EAST SIDE LOW LIFE is offline   Reply With Quote
Old 09-09-2007, 03:09 PM   #5
68gmsee
Active Member
68gmsee's Avatar
In your case, it could be the internal sending unit as Longhorn mentioned gone bad, could be the float arm jammed up at an odd angle, or the wire, or metal cap going to it shorted to ground. Check the rubber grommets, etc. on the sending unit. They can break with age when handled...
It may be time for a new one...
Here's a site you can read. I believe it's the same for all year trucks.
http://www.6066gmcguy.org/Electrical-02.htm
68gmsee is offline   Reply With Quote
Old 09-10-2007, 09:31 AM   #6
RicksTrucks
RicksTrucks's Avatar
How much was the cleaning and do you know what they used?
68 Short Stepside C-10
69 SWB C-10
70 Flatbed C-20
70 LWB C-20 BB402
70 LWB C-10 CST
70 LWB C-10 CST
71 Short Stepside Cheyenne C-10
72 LWB C-10
72 Blazer 4x4 4spd
95 Jeep Cherokee 4x4
RicksTrucks is offline   Reply With Quote
Old 09-10-2007, 10:00 AM   #7
Alex Hayley
I had exactly the same problem this past week. Following http://www.6066gmcguy.org/Electrical-02.htm, everything checked out. So, with the ignition switch in the ON position, I tapped the gauge and it dropped back down where it should be. I hope this solves my problem. Let me know if this works for you.
Alex Hayley is offline   Reply With Quote
