09-09-2007, 08:13 PM | #1 |
Serpentine with factory Steering gear
Converting to serpentine system with the late model power steering pump but retaining my stock gear. Will the fittings be different?
Can anyone point me in the right direction for hoses/fitting adapters? Thanks
Maj USAF 71 K5 Blazer CST 72 K20 HT383 NV4500 Mass-Flo EFI 71 K10 LWB 52 Dodge Power Wagon 67 Dodge WM300 Power Wagon 48 Dodge WDX Power Wagon My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=239487 |
09-09-2007, 08:47 PM | #2 |
Re: Serpentine with factory Steering gear
I assume you are talking about the serpentine setup from GMPP or off of a 90's camaro, right? I believe they are different. BUT, you can unscrew the fitting from the back of your existing pump and screw it in to the new pump. Then you can use the stock pressure hose.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build Last edited by smbrouss70; 09-09-2007 at 08:50 PM. |
09-09-2007, 08:59 PM | #3 |
instagram "footbraker67"
I switched my 67 over to a factory serpentine system, and all i had to do was use my stock metal line on the gear and find the stock style fitting and line coming from the pump(Its off of a 90s model pickup)and take it to a shop that makes hoses and have them put them together with some hose. turned out real well on mine, shouldnt be very expensive either.
09-09-2007, 09:01 PM | #4 |
I had problems with my "old" style hose running into the frame so i went this route.
09-09-2007, 09:03 PM | #5 |
Thanks for the info Chevelle. On another note, is that the air conditioning compressor on the driver's side? My other dilemma is figuring out what alternator to us with the serpentine system.
09-10-2007, 06:16 AM | #6 |
Use one of the newer CS style alts, whichever one fits the serp bracket you have (there are different size mountings).
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
09-10-2007, 05:45 PM | #7 |
http://67-72chevytrucks.com/vboard/s...d.php?t=254812
I have a cs130 from my serpentine setup for sale that will work. It works fine, had it on for awhile, upgraded to a powermaster side post, big stereo, electric fans needed some more juice.
1986 C10 SWB 6.0/6l90e Miami...Flee it like a native |
