HEI again
I have been reading about how great this is, and now I am ready to try it. I have a distributor from a 78 malibu, good condition. I know I need a 10 guage wire with an inline 20 amp fuse from the unfused ignition side of the fuse box(? don't I ?) I will be running r45ts plugs gapped to .045.. My question is this.... where does the wire attach to on the dizzy? It has a plug with 3 wires, 2 red and one black... where do I attach the wire? Any other suggestions I have missed?
oh and by the way, I LOVE THIS BOARD!!!!
57 suburban(sitting in the driveway), 2 69 C20 longbeds (sitting in the field ) and a 2003 8.1 Suburban ![]() Endeavor to persevere. "All of a sudden, I'm the old timer!" Some old timer on American Pickers. |
Used to have a truck
10 gauge wire is overkill. It wont hurt but having a larger wire than 14 gauge isnt going to help anything either. So if you have 14 gauge wire sitting around dont make a special trip. If you dont then pick up some 10 gauge when you go to the store. It wont hurt.
There are two open terminals. The wire terminal closest to the firewall is the one to hook your power lead to. The one towards the front of the motor is the tachometer terminal.
No truck :-( |
you should have 2 more teminals in front of that plug one is for your tach and the other is for the power feed. hold the dissy in front of you with the connection block at you right hand this should be how it will look once you get it in the truck. leave the 3 wire plug connected and look for the other 2 the front one will be for the tach and the aft ont will be for the power. it should also be cast into the top of the cap. good luck
04 GMC Sierra RCSS 70 CST LWB 04 HD Sportster 1200 Custom |
Thats the Hillbilly way
speesh FYI
I been running a 12 gauge wire with a 5 amp fuse ,no problems Good luck
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , |
12 gauge wire should insure that you get a full 12V to the dist/coil
