09-15-2007, 05:29 PM | #1 |
It's the air up here
Floor pan separation
Are the floor pans glued together as factory? Mine are starting to separate, and am not sure if I can bolt them or just align and re-glue? I noticed this from under the truck not from inside the cab.
1971 cheyenne k10 4 speed np 205 454 BB factory a/c Never drink down stream of the herd! Eric |
09-15-2007, 05:43 PM | #2 |
Re: Floor pan separation
I would think bolted or spot welded yes...but not glued. A Ford or Dodge might be glued together. It's possible that there might be some sealer on the floor pan.
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! Last edited by 70cst; 09-15-2007 at 05:45 PM. |
09-15-2007, 05:52 PM | #3 |
Well they are definitely not bolted, and all I can see is sealer or glue. No spot welds that are visible any way. What can I do?
09-15-2007, 06:37 PM | #4 |
bolt it back together for spot weld
09-15-2007, 09:26 PM | #5 |
what you are probably seeing is seam sealer ... it's not a glue, but more of a "caulking" the factory used where two panels joined & spot welded. It's used to help make the panels water proof without welding them solid.
