Rottenwood Garage Member
67-72 dually wheels/rims.....what crosses over?
Are they the typical 8 on 6.5. I want to get rid of the split rims and move to something newer. Can I go with the
1) most years GM 2)Ford to 1999 3) most all Dodge I was told the new GM stuff wont work WHAT CAN I USE????????
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! Last edited by 72freak; 08-23-2007 at 06:30 PM. |
Re: 67-72 dually wheels/rims.....what crosses over?
http://www.stagewest4x4.com/store2/s...lt-pattern.htm
I dont know if that will help any, I just skimmed through it... Last edited by racerman85; 08-23-2007 at 06:41 PM. |
#3 | |
Anyone else?????????
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
its all about the +6 inches
if you plan on carrying heavy loads, you'll need to stick with GM wheels so the hub will carry the load, and not the wheel studs.
Designated Grumpy Old Man
![]() Join Date: Oct 2001
I found Weld wheels will work.
Never let the truth get in the way of a good story 71 Chev 1/2 ton 4X4 LWB Fleetside SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=361222 http://www.youtube.com/watch?v=1LgREwtDfaA 68 Chev 1 ton flat bed http://www.youtube.com/watch?v=0bO8szzlD4A 56 Chev Handyman Wagon http://www.youtube.com/watch?v=9y-6ddpBTkM http://www.youtube.com/watch?v=lbLzZ7zY8wA 56 Chev Belair http://67-72chevytrucks.com/vboard/s...d.php?t=410667 http://www.youtube.com/watch?v=xoW0Ei7ZNIg |
Ok.........so if anyone has any..........Im in the market
![]() Join Date: Mar 2003
I put some 1981s on my 69 ----- not the best pic of the wheels
The drum brake trucks have smaller studs and flat-back castle-type lugs.The disc brake trucks have bigger studs(& holes in wheels)and use chamfered lugs with spreader rings with beveled seats to center lugs on stud on GM.I ran late wheels on a`70 for awhile with no problem.But,later drilled for larger studs,beveled the holes in the wheel,and went with the conical lugs.
The rims you are looking for are called bud wheels i have them on my one ton
1967 chevy one ton wrecker truck |
#10 | |
So it looks like after 87 GM went to a metric stud. Can I just use a nut that is tapered to make up for the diference in the hole?? 65-87 8 on 6.5 in. 9/16 88-04 C3500-K3500 1 TON & HD 2/4WD 8 on 6.5 in. 14X1.50
72 C30 Trailer Queen
I cut and pasted this from a previous post I made, but it is worth repeating:
According to Accuride's wheel catalog, wheels from 1976-2000 C/K trucks are the same (16"x6", part #29587). These wheels have a 4.56" center bore, and are supposed to be used with a clamp plate and 90 degree cone nuts (clamp plate is GM part #472536). Previous to 1976, the factory single piece wheels were 16.5", and they will work too. 1971 and 1972 C30 trucks have the larger 9/16 studs, so the wheels are a bolt-on. 1967 1968 1969 and 1970 used 1/2 studs. I had always thought of having some small bushings made to fill the gap so the wheel couldn't rotate (I had a 68 C30 motorhome). The alternative was to install the bigger studs (or take your chances) You can get by with less, but its hard to justify when you think of what might happen if you lose a wheel or break all your studs. Much easier to make things right in your driveway!!!
Chris H 72 C30 133" 72 C30 157" flat-dump 69 C10 short fleet 71 ElCamino 2000 K2500 crewcab shortbed (sold, sorry old friend) 2005 GMC 2500HD shortcrew Duramax 2006 K1500 RCSB and a couple other projects/parts |
I have a radical idea!
I re-drilled the drums and went with 9/16 on my '69 C-30 car hauler, and 14mm on my '67 C-30. 9/16 measures .562 and 14mm meaures .551, so they are very close in diameter.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
I'll be honest... I have always run 71 and newer 9/16 stud hole wheels on my 2 70 longhorns with 1/2 inch studs.
While I have never had an issue, I would NOT do it on something that is always loaded. The lig nuts and studs don't take the load on a properly futted hub excentric wheel. All they do is clamp it to the hub. The cone shape on the smaller lugnuts do full the larger hole of the later factory wheels. however, there IS some room in there, and with heavy loads on a regular basis, it could be an issue. The empty pick up with the ocasional heavy load... I've never had a problem. I do check lug torques before and after heavy loads due to this, and also inspect lugs, nuts, and wheels whenever they are off. |
I forgot to mention that before I had put those rims on my 69 I had already swapped out the rear axle to a Dana 70 hd and converted the front to disc ---thus already having the larger wheel studs.
#15 |
I noticed that in your picture.That`ll fix that.I ran the newer chrome Budds on my`70 work truck (which weighed alot w/o cargo) on the small studs with quite a good bit of weight on it pretty much all the time.I eventually remedied it,but did this for a couple years of daily use.Call it dumb luck,but never a problem.I can`t imagine why the rear wheels wouldn`t want to "rock" on the studs,but it didn`t.And`I never rotated the tires or removed any during that time.
1990(I just talked to that kid last night.He`s 30 now ![]() ![]() ![]()
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 08-25-2007 at 06:26 AM. |
#16 |
OK dually dudes..........Thanks for the wheel help and keep the comments comming...................NOW my other question. I probably should start another thread.
Once I do my duallly "regular truck bed" conversion and my wheel swap..........I get the feeling that the truck is goung to ride fairly high in the rear. I would like to try to level the truck out a bit. On a C-30 2x4 what can I do??????? Can I raise the front? Can I lower the rear? How is it done Thanks UPDATE..........I went out there today to check it out. It looks like the rear axle has bigger studs than the front. The fronts are flat and have small studs and the rears are the bigger ones with a retainer ring and angles nuts. Ant thoughts?
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! Last edited by 72freak; 08-25-2007 at 02:48 PM. |
#17 |
There are drop shackles made.There`s axle-flips(axle over leaf).You don`t want to give up load capacity,right?
Something I have pondered is:How about lightening up on the leafs,like running ECE lowering leafs?Then install Airlifts or Firestone auxilary bags.You could air down for your lower ride until you need the capacity and the add 1,500#.Or...run those springs and have heavy overloads set up to do all the work when loaded.Find guys with lowered`73-up Dooleys and ask what they do.Most probably are basically running 1/2t suspension.But,I see guys using lowered trucks to tow and other duties.
#18 |
most slammed HD trucks are on air bags, which, is the only real way to have lowness, comefort, and pay load capacity.
That's what I want to eventually do with the longhorn. |
#19 | |
I dont mind a 4x4 look if need be.
#20 |
I don't know if you can get that much lift without getting into geomitry issues.
However, i honestly never looked into it either. |
#21 | |
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 08-25-2007 at 10:48 PM. |
#22 | |
Taller springs coil spring spacers spring spreaders Looks like you can gain up to 3" without changing anything and up to 5" with slight suspension component changing and of coure re-allignment.
