![]() Join Date: Aug 2006
Re: Laying frame on 71 C10 questions
You really can't just slap on the rack and pinion and be all good. The placement of the rack is very important. If the rack is off 1/8" from where it is needed to sit you will have more bump steer. If you decide to go with the rack you really need to do your homework to find out where it needs to go EXACTLY before doing it. Good Luck!!!!
Josh
(Project truck) 1970 C10 under complete transformation ![]() My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871 Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold |
#2 | |
#3 | |
Thanks for all the responses! ![]() |
If your fabricator is familiar/experienced with suspension/steering geometry and design the hardest part will be modding the factory member to accept the mounting points for the rack. Like others have mentioned, it is critical to locate the rack properly... if it's off just a little, it can cause some really funky steering issues. There is a reason that more peeps aren't running a rack and pinion/factory crossmember set-up.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
#5 | |
Seņor Member
(OK, PB... where's my $5 for the big pitch?) ![]()
