09-16-2007, 08:38 PM | #1 |
Active Member
Just a coupe of pics of my 454 & new wheel trim
I thought you folks might like a couple of pictures.
1 is of my new trim rings, center caps knock off's & Hoosier pro street radials. The second is of my 454 which is almost ready to drop in. 30 over, 9-1 compression, comp cams 280H, roller tip rockers, Summit SFI damper,Jackson gear drive, Edelbrock Performer RPM intake, Large oval port heads with minor porting, SFI flexplate, Al water pump, Melling oil pump, Miladon oil pan, Holley 770 Street Avenger
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles 18.5" x 31" Hoosier Pro Street Radials ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree |
09-16-2007, 08:59 PM | #2 |
Ever heard of Beech Island??
Re: Just a coupe of pics of my 454 & new wheel trim
nice lookin motor. I love the wide tires
09-16-2007, 09:02 PM | #3 |
67-72 Addict!
LOVE the tires also!. What size and what mods were required to get them under there?. I want them on mine!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
09-16-2007, 09:12 PM | #4 |
Well, Whoop-dee-do!
Wow! now that is some nice rubber- sitting in the wheelwell right on the money
Couple of questions- -Do those big meats clear the stock frame/ suspension? -Are those Dodge taillights? -Do you need a longer gun/ lead for that Snap- On welder? I used to have a YA212IND, and hated the short lead it came with. Later on after the gun was getting bad, I bought a new gun with the longest lead they had. I don't have the welder anymore, but still have the barely used gun/ lead in the original box.
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD '72 K20 500 Cad/TH400/NP205 SOLD '92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver '72 Monte Carlo... sweet low mile toy '11 Dodge Challenger IE 392 6spd... midlife car |
09-16-2007, 09:29 PM | #5 |
Active Member
The rear tires do clear the stock suspension, with exception given to the springs. One has to change to a non taper style spring - the same style used in the front suspension. The bed floor needs trimed back to the frame rail.
The emergency brake cables need to be pulled away from the edge of the wheel otherwise they will rub the edge of the wheel. No they are not dodge taillights. 18.5" x 31" Hoosier Pro Street Radials on 15" wide wheels with 9" of - offset
09-17-2007, 12:22 PM | #6 |
Now that's a tire!
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
09-17-2007, 01:12 PM | #7 |
Farm Truck
Show us the whole truck.
1969 CST/10 1984 K5 Blazer 4x4 2016 Dodge Ram 2500 4x4 Mike Jersey Village, Tx |
09-17-2007, 01:34 PM | #8 |
Yes, show us some more pics.
Anybody can restore a classic, takes a man to cut one up..... http://www.arnoldscustoms.com |
09-17-2007, 02:02 PM | #9 |
"chirp"!!
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
09-17-2007, 03:52 PM | #10 |
Active Member
"chirp"!!
????? - How About BARK!!!! I will shoot some more pics next week after the transplant which I hope will be done by this Friday.
