Old 09-17-2007, 08:11 PM   #1
60ratrod
yes, i do
60ratrod's Avatar
Question throttle linkage swap
so while i'm hear in fallon, nv, so far away from my truck, i'm thinking of stuff that i wanna do to it. so now my question is, how hard is it to change from the old rollerball bar linkage to the newer cable style throttle linkage and how much would i be looking into for parts and how difficult this can possibly be?? when i put my carb spacer in it raised my throttle bar in the cab so much that i can't use the oem pedal any more. so for those of you who have done this before lemme know.
60ratrod is offline   Reply With Quote
Old 09-17-2007, 08:45 PM   #2
Dadsredwagon
Dadsredwagon's Avatar
Re: throttle linkage swap
Everyone here suggest LOKAR, but I need some pics so see how it will work?
Dadsredwagon is offline   Reply With Quote
Old 09-18-2007, 12:31 AM   #3
Fastrucken
Junior Member
Fastrucken's Avatar
I used a pedal assembly and cable from a 87 suburban only a little fab nessary
A good friend will come bail you out of jail, but a true friend will be sitting next to you saying, "That was ****ing awesome."
Fastrucken is offline   Reply With Quote
Old 09-18-2007, 06:43 PM   #4
rodnok1
rodnok1's Avatar
You should try a search on this..or maybe check the next page...
http://67-72chevytrucks.com/vboard/s...d.php?t=258577
64 Panel Rebuild Pics
Clutch Replacement and Borg Warner T10 Trans Rebuild
64 Panel 1/2 Ton
350cubes/400hp
BorgWarner t-10
3:73 Auburn Posi
rodnok1 is offline   Reply With Quote
