I got my new car craft in the other day and one of the articles is about a company making a kit to install our truck style rear suspension in a chevelle. The article calls it the ultimate suspesion. The trailing arms are modified to accept a different tracking arm. Bolts directly to one of the trailing arms then a bracket attched to the frame. Good article, you may want to check it out.
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
Fabricate till you "puke"
Jan issue of Car Craft?
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Or check out the website 'Hotrodstohell'.com. From what I've seen the geometry of these truck set-ups @ stock height isn't very good for cornering, but bring the center of gravity down & things get alot better. The adjustable panhard bar is trick.
its all about the +6 inches
Yeah, i saw that too. Did you see the 68 GMC and the 67 Chevy truck they showed?
One of us needs to write them a letter...I know Sr Ed King has a 71 or 72, and he used to have a 67 short step that was awsome. |
Whats the name of the company that makes this kit? I left me car craft mag at my parents and I just wanted to read up on it.
1969 Chevy Project SWB Fleet, 20s, 5.3, t56, in the weeds. 1970 Chevy Truck cab on a 1979 Jimmy frame-8.1 liter 496 bbc/sm465/np203-jeds doubler-np205/d60/14bff Welded/42 tsls on recentered H1s 1998 Chevy Crew Cab K3500 SAS'd with hpd60, links and swayaway coilovers. 8.1l vortec DD/towrig "I like long walks, especially when they are taken by people who annoy me. " |
nm its www.hotrodstohell.net.
The interesting part in the Car Craft article is that they say that this is the type of suspension that has been used in NASCAR ever since the early sixties when it first came out in trucks (and still is?). There is even a rumor that they started using this trailing arm type of suspension in the pickup trucks so that they could use it in NASCAR.
Tim |
