09-18-2007, 11:28 PM | #1 |
A/C condensor question
Does anyone know if there is anyone making bolt in replacement condensors for 73-80 trucks that is designed to work with R134a ? I really want to change my condensor and do not want to use the old coil type . I would prefer a new style cond. If not has anyone installed a later model unit and if so what did it come from ? Pics would also help . Frank
Born and proudly residing in a Red State ! |
09-19-2007, 08:16 AM | #2 |
The Crazy Machanic
Re: A/C condensor question
are u talking aboutthe long one or the smaller on my hevelle has the long ont that about the size of the engine head. and the other is about the size of a pie pan.
and then there is this one but i dont have any eperance with
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day) * 1970 chevelle 2dr sedan Latest update June 24 2007. *1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad) newest additions 1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in and a 79 c60 trash truck um no idea i have one |
09-19-2007, 09:45 AM | #3 |
What Hump?
Srubydo1986 that's the compressor I believe he's talking about No. 1 on this lmc page. In answer to your question - I don't think so, when I went to APAC here in phoenix, this is a air conditioning parts store, they made no mention of a updated condensor when I told them that I was changing over to r134.
Lil red 86 c-10 99 Sub 78 Camper Special w/ 454 |
09-19-2007, 09:53 AM | #4 |
On a budget like Fred Sanford
I just did the r134 conversion and checked into this.....nobody makes a new style condenser for our trucks. There's so much space up there though, I imagine a condenser from just about anything would fit ok.....it would just take some custom lines to make it work.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
09-19-2007, 09:58 AM | #5 |
I looked and looked for a bolt in parallel flow condenser with no luck. All I was able to find is a universal one. I bought this 19.5x30.5 condenser from ACKITS.com
click on the pic It should be easily adaptable to the stock lines with a couple short hoses. on my truck, I am replacing the GM compressor with a Sanden and will have custom hoses made.
- Greg |
09-19-2007, 10:30 AM | #6 |
I forgot to mention that if you do switch to a condenser of this style, be sure to put an in-line filter in the line between the compressor and the condenser. These pf condensers cannot be flushed effectively if the compessor fails and pukes debri.
- Greg |
