Old 09-20-2007, 08:46 AM   #1
prg machine
prg machine's Avatar
Instal headers from above???
I have an engine soon to instal in a K truck, front clip, fenders off. The headers are the long tube Hedman. Without the starter on and the spark plugs out, can the headers drop in from the top. ??? Any other methods?
prg machine is offline   Reply With Quote
Old 09-20-2007, 09:37 AM   #2
lost wages
lost wages's Avatar
Re: Instal headers from above???
some headers can be installed from the top some cant, if your pulling the engine to drop in a new one, lay the headers in the engine compartment and tie them up off to the sides out of the way, then drop the new engine in.
lost wages is offline   Reply With Quote
Old 09-20-2007, 05:25 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
You'll want that starter to be installed BEFORE you put in the headers.
Old 09-20-2007, 05:34 PM   #4
prg machine
Got it. Maybe instal the starter on the floor and then tie off headers and instal engine. I wonder how this will work with SM465 and 205 transfer goin in also????
Old 09-20-2007, 08:07 PM   #5
Long Roof
Old School, New Style
Long Roof's Avatar
Starters a pain no matter which way you go. I installed the engine with the headers and starter mounted and it was a real PITA to get the starter wires on. When I pulled the engine I took the headers out from the top but I had to drop the starter and the oil filter to do it.
The Good:
- 72 GMC Jimmy 4x4 - 307 cid / 350 th
- 70 Chevy Suburban 1/2T 2wd - 454 cid /400 th
- 96 Chevy Impala SS - mainly stock
- 98 Chevy Tahoe LT 4x4 - all stock
The Bad:
- 86 Chevy Suburban 1/2T 4x4 - winter beater
The Ugly:
- 72 Chevy Suburban 1/2T 2wd - parts truck
Long Roof is offline   Reply With Quote
Old 09-21-2007, 01:29 AM   #6
WinDancer
The Original HotRod KnifeMaker
WinDancer's Avatar
My full tubes in a 69 GMC 1/2 ton required the engine almost down on the motor mounts with a jack under the motor to squeeze it up a little then down a little. Then one side, then the other. These are made for our trucks but the sure don't act like it on install..........
Dave
69 GMC SWB 2WD 454 Turbo 400
WinDancer is offline   Reply With Quote
Old 09-21-2007, 02:19 AM   #7
EAST SIDE LOW LIFE
EAST SIDE LOW LIFE's Avatar
Thats a Headman Long Tube on the shop floor that I removed today. I removed it from the bottom starter side and only had to remove the plugs. It's a real bear to get out and the starter is a real drag to install with headers in cause the wires are next to impossible to connect. In your situation I think I would try to work with installing the starter first then the header from the top.
esll.
Tomorrow is for doing today's stuff.
This truck has just the right amount of energy for me!
Author: Warren Lake .... (member)
EAST SIDE LOW LIFE is offline   Reply With Quote
Old 09-21-2007, 06:09 AM   #8
72armyswbtruck
72armyswbtruck's Avatar
Yup, I just removed my headers and went with stock ramhorns. Easier on the plugs and all around easier to work with for the minimal power gain.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 09-22-2007, 08:19 AM   #9
prg machine
What I will try is headers tied to side. Engine and tranny transfer goes in. Then starter. wire starter then bolt up headers.
Maybe????
