6 cyl engine/trans mounting-how to? Pics please
Ok my truck was disassembled when I got it so I didn't see how things were mounted and put together. What I'm needing now is some pics of a 250 I6 from the side and the motor mounts. I've been looking for parts and have seen that there are rear engine mounts. Where do the rear engine mounts connect to the engine and to the frame. Just looking at my truck I don't get it. I'm a visual person and learn better by pictures (don't tell my wife that
![]() If anyone has any pics of how they mounted their I6 and transmission i would appreciate it. Thanks a bunch.
1978 Chevrolet Silverado 3/4 ton 400 small block. 2000 F-250 Powerstroke 2002 GMC Yukon Denali XL |
Re: 6 cyl engine/trans mounting-how to? Pics please
ttt
Active Member
![]() Join Date: Jul 2007
As the saying goes, "A picture says a thousand words." I hear you about "pics." I think most of us are that way.
I have an inline six on my 68 GMC but it's 30 miles out in the country. If you don't get someone else that can post a pic, I will try to get some for you this weekend. Anyway, here's a bump ttt for you. |
![]() Join Date: Jan 2000
I don't have a pic, but there is a crossmember that the bellhousing bolts to. The rear mounts look like transfercase mounts. Upper and lower rubber with a bolt through them. Some one I'm sure has a picture. The manual crossmember is different than the auto crossmember.
70 Jimmy 4x4 71 GMC 2500 Too bad stupidity isn't painful |
Out of the carpool lane.
I'll try to get pics today. I'll be working on getting my T-5 back in anyway.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
Active Member
mvfd70, don't know if you still need the pics of the rear of the inline six. Here's a couple I took today. If you need another angle let me know. I'll be back out where my truck is tomorrow...
Pardon the mud dobbler's nest. I need to get in there an clean up the &*%$ mess they make... ![]() ![]() |
Thanks. Those pics are what I needed to see. I didn't think the transmission was going to support the weight of the back of the engine. My truck originally came with a 3 speed. Was there no rear transmission crossmember for that?
1978 Chevrolet Silverado 3/4 ton 400 small block. 2000 F-250 Powerstroke 2002 GMC Yukon Denali XL Last edited by mvfd70; 09-22-2007 at 10:37 PM. |
my dad's 71 GMC with 250 6 and 3 OTT does not have a trans cross member. I thought someone had taken it out,but I looked at another truck a buddy just bought, a 72 w/ 6 cyl and 3spd and it did not have a trans cross member. He said he had another 72 like it a long time ago and it also did not have a trans x member. I wil try and remember to ask my bro. , as he had a 72 5 cyl 3 OTT truck yrs ago. He might remember
Ok that helps a lot. I thought the crossmemeber that is there was the tranny crossmember. I did not know how the engine and trans were gonna fit there. It all makes a lot more sense now. thanks
Active Member
The standard three speed sixes did not have the crossmember for the trans. When I saw mine for the first time, I thought the same thing you all did.
Now I have a fully synchronized saginaw three speed on my GMC. It has the place in the rear for a rubber trans. mount but I just installed it like my previous non sychronized trans. with no crossmember. |
