#1 | |
3DrDwn--the 'burb not the band
Re: Street Rod Sugar Daddy (Dino63's 78 C-10)
The Watts is the superior but slightly more expensive route do to it's more complex design. It will allow full range of motion with minimal, if any, side to side movement. |
"Slightly more expensive" may be a bit of an understatement.
When Nathan was designing my suspension the Watts Link made it almost $300 more. Watts Link for 12 bolt is about $350 After checking clearances and possible space issues I decided to go with a triangulated 4-link which was a fair amount less expensive and you get basically zero side to side movement as you do with the Watts Link. Your useage could have space issues with the triangulated so be sure to check it out before you go this route. Make sure you have somewhere for your tanks, exhaust, etc.
Jim '71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E '57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works '87 BMW 325i - daily driver |
#3 | |
OG
Nice! Only reason im asking is because alot of people ive seen only installed the 4 link and canti setup. I want to do it the right way pan hard bars are cool but im impressed with the Watts link.
I try to use watts exclusively now since doing my first on our 92 Tow pig. It is a frame laying, 2.5" stock floor body dropped chevy crew cab dually. I Originally built it with a panhard bar but it was getting into the dually fenders.
A lot of guys will tell you towing and air don't mix but this thing is overbuilt and a triangulated 4 link wasn't an option. Watts were starting to pop up in the scene and so I built my own after talking to a few guys who were using them. Truck has about 25k miles on it since install and other than road grime still looked pretty new. We use it primarily to tow another extra-cab dually, a 64 impala, or 55 pro-street to shows. here's a small pic: ![]() |
