09-20-2007, 08:48 AM | #1 |
Tot Roddin'
Looking for original guages with white faces
At one time, I believe that there was a board member that was refurbing the guage clusters, to use original guages, but have white faces painted on with the original lines.
Anybody recall what I'm talking about? Or am I crazy???
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
09-20-2007, 09:13 AM | #2 |
I have a radical idea!
Re: Looking for original guages with white faces
Look up Byrd. He does them. Here is the gauges in my '69 C-30 car hauler. I bought a kit from Ebay for $20 and did my own.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
09-20-2007, 09:19 AM | #3 |
You can buy em on ebay. The seller is whitegauges.net
I bought his kit and did my own. The kit comes with everything to do a 5 hole cluster too and he sells tach and vac covers if you need em. You basically clean the gauges really good, put the stickers in soapy warm water, align them, use a soft cloth to push the bubbles out, then use a hair dryer to "shrink" them to fit. Don't use too much heat, they will melt. Also, you want to paint white in areas where the stickers won't cover first (they're not perfect.) You also get an A/C controller one too, so I did that as well. Here's mine.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 09-20-2007 at 09:21 AM. |
09-20-2007, 12:59 PM | #4 |
67-72 Addict!
This is what they look like with blue refractor LED bulbs behind them
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
09-20-2007, 01:40 PM | #5 |
Self-proclaimed LED man
Yea, whitegauges.net will work. I bought mine from Durangedesigns.com. I think they are now the same site. Here's a link to the ones for our trucks. http://www.whitegauges.net/whitegaug...productsID=976
My LED Website My Photobucket Album of LED's Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK I also do LED: -Third Brake/Cargo -Brake (truck and burb) -Reverse (truck and burb) -67-68 Front Turn Signals -69-70 Front Turn Signals -71-72 Front Turn Signals -GMC Front Turn Signals I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once Norwood Survivor |
09-20-2007, 04:53 PM | #6 | |||
Union Electrician
Like this?
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5" Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
09-20-2007, 06:00 PM | #7 |
70c10 Those are awesome!
09-20-2007, 07:48 PM | #8 |
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
09-20-2007, 07:55 PM | #9 |
67-72 Addict!
Thanks kyull67!. byrd taught me everything I know. He is the gauge master!
09-20-2007, 07:57 PM | #10 | |||
Union Electrician
Master nah, just done one or two
09-20-2007, 08:24 PM | #11 |
Here's mine. Top 3 gauges are factory and work fine. I repainted the faces white and touched up the needles with a little more day-glow paint.
The lower 4 are aftermarket (Sun Pro I think). I tossed out the nearly 40 year old failure prone flexible wiring and hard-wired everything. Took a while but it works like a charm.
69 C-10 SWB Fleetside 454/TH400 (For Sale) http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12 70 El Camino 454 TH700 29 Model A 4-DR Sedan Deluxe |
09-21-2007, 01:48 AM | #12 |
I bought one from Randy (Byrd) on Ebay and they look even better in person. Great work and it was well worth what I paid for it being that you could tell there was a lot of pride and attention to detail on his finished work. I have yet to install it, but I am sure it will look great once I do. |
09-21-2007, 08:37 AM | #13 |
70c10
Where do you get the LEDs for your gauges? |
09-21-2007, 09:01 AM | #14 |
i was wondering the same thing on the leds, also, which tac it that? that would be much better than my hose clamped on the steering wheel job...
if those LED's arent that much work, i'm def gonna get the white gauges with colored LED's, thats HOT! |
09-21-2007, 09:12 AM | #15 |
i see whitegauges sells the LED's, i'm gonna get some, but is there a cheaper place? 5 bucks for a few LED's to replace a few cent bulb is a lil expensive, but def. worth it if there is no other option...
09-21-2007, 10:05 AM | #16 |
67-72 Addict!
I got my 4 refractor LED's off ebay. Each bulb has 5 LED's in them. They run about $3 each bulb and the light dispersement is nice and even. The tach is a Sunpro 3.5".
09-21-2007, 12:12 PM | #17 |
Those guages look great, but also pretty bright. Any problems with the LED's becoming annoying after an hour or so behind the wheel?
"You can take the man out of PA, but you can't take PA out of the man" |
09-21-2007, 01:36 PM | #18 |
67-72 Addict!
Nope, mine are dimmable but the pic makes them look brighter than they are.
09-21-2007, 02:21 PM | #19 |
Tot Roddin'
That's exactly what I'm talking about. What did you/do you charge for a full set?
What kind of paint did you use to paint the guage itself? Did you purchase some of the kits the other guy's were talking about?
09-22-2007, 11:35 AM | #20 |
I want a set of the silver overlays, Bird you still doing those??
"OLE BLUE" Goodwrench 350, 5speed, Tilt, PS, PB, "some guys got into cars for money or girls but i got into cars because of the cars" -Jay Leno |
09-22-2007, 02:14 PM | #21 | ||||
Union Electrician
I use the decals like the others, but also do a host of other things like testing, blasting, painting, different lense, lots of TLC, refurb the speedo and zero it out. PM sent
09-22-2007, 02:18 PM | #22 | ||||
Union Electrician
Sure do, PM sent
09-23-2007, 10:20 PM | #23 |
Tot Roddin'
Thanks for the info Byrd! You do excellent work.
09-23-2007, 10:26 PM | #24 |
any links for the blue refractor LED bulbs
