09-23-2007, 09:15 PM | #1 |
Luv the Crewcabs
Alternate To Wood for A Stepper Bed???
Wood Bed in My Project Truck is Shot & will need Replacing, Just wondering if anyone has Come up with Alternate to using Wood?? What Did you Use & How did you Do it?? Any Idea's On This would be Appreciated...........
Thanks, Rick |
09-23-2007, 09:17 PM | #2 |
Re: Alternate To Wood for A Stepper Bed???
I'll probably just use a sheet of plywood in High Step for now but would like to get some Diamond Plate for it eventually..
09-23-2007, 09:48 PM | #3 |
laying low
Well for most show trucks wood is the norm. Metal sheet is often used for a daily driver/ work truck. I am giving some thought to using a composite type home deck material. Trex is one brand, there are several. It's not cheap but it is durable and will not rot and comes in different colors.
09-23-2007, 09:51 PM | #4 |
WTB this ad
There was a member who used Trex and posted some pics quite some time ago. I don't remember who it was but it seemed to look and work quite well for a daily driver.
09-23-2007, 09:53 PM | #5 |
Luv the Crewcabs
Thanks for the Input, Also Thought about Putting Steel down & Having the whole bed Herculined also, Would like too See That if anyone has Done it??????????
Thanks Again, Rick |
09-23-2007, 10:11 PM | #6 |
I have also considered using some type if silestone countertop , or other engineered wood instead of actual wood. Although if you take care of it the wood we have now will last a really good while.
SHawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
09-23-2007, 10:25 PM | #7 | |
Luv the Crewcabs
Rick His Link............ http://67-72chevytrucks.com/vboard/s...highlight=trex |
09-23-2007, 10:38 PM | #8 |
The wood lasted a long long time.In a highly cared for classic it will last even longer.In many cases the sheetmetal rusted before the wood rotted.I built a pro-street Stepside and used a steel Fleetside bedfloor and wheelhouses.
09-23-2007, 10:42 PM | #9 |
Mikenutt has the composite stuff in his bed. I've seen it in person and I though it looked really cool. I plan on borrowing his idea when I get to that step.
72 C10 lwb fleetside -stock 350/350 combo |
09-23-2007, 10:47 PM | #10 |
I have heard that stuff bleachs out real fast in the sun any truth to this?
09-23-2007, 11:02 PM | #11 |
I think Trex is fugly.I use it alot.Sierves it`s purpose,but looks like particle board,IMO.
09-23-2007, 11:05 PM | #12 |
Luv the Crewcabs
09-23-2007, 11:15 PM | #13 |
Trex is very expensive....for the money you would spend on that stuff [and it's not even waterproof] you could have a very nice wood bed. I am 90% sure Trex doesn't come in 1x8 size for the big boards....not sure what you'd do since Trex cannot be glued up like normal wood.
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
09-24-2007, 02:36 AM | #14 |
I put in a sheet of the most expensive 3/4' Birch plywood Home Depot had. ($30), wanted to get the thickest veneer possible. The bed was 3/4" too wide for the sheet, so had to add a "frame" around it, but I still think it came out great and I load all kinds of stuff in it, including my new engine, and it is very solid. Not sure how wide a standard bed is, mine is pretty rigged up, so I don't know how a standard 4 foot wide sheet would fit on a "good" bed. Going to do Pine and build myself (with Kelly's help i am sure ) and do the normal wood bed kit when I install my replacement bed.
Link to the page for all the pics of the install: http://www.grossepointegothic.com/71stepside/woodbed/
_______________ Thomas '78 Silverado '74 Monte Carlo '47 Teardrop Trailer East Texas Classics Local Club |
09-24-2007, 07:28 AM | #15 |
Orange Truck
I would stick to wood. I used the oak kit from the firm in Oklahoma. This is class stuff. It comes groved and holes drilled and counter sunk. Although already finished, top it off with a sand of the finest paper and three coats of marine varnish. Then dress it up with polished stainless stell strips and fastners.
09-24-2007, 09:11 AM | #16 |
http://67-72chevytrucks.com/vboard/s...d.php?t=195408
here is a link to some pics of my steel floor i built....the cost was around $150.00. steel has gone up since then.... |
09-24-2007, 11:39 AM | #17 |
so easy a caveman can do it...
I think some kind of composite decking material would work great if you want the look of a wood bed, but not have to worry about messing up a nice new wood bed. As far as size of the planks compared to the original...just drill new holes for the 5 1/2" or so wide composite
09-24-2007, 12:19 PM | #18 |
72 C30 Trailer Queen
http://www.rumber.com/truck_products...ruck_beds.html
Here is a website for "rumber", which is a rubber composite lumber product (sheets and boards). Manufacturer makes it sound bombproof. IIRC, there was a red stepside truck here that had a similar product in his bed?
Chris H 72 C30 133" 72 C30 157" flat-dump 69 C10 short fleet 71 ElCamino 2000 K2500 crewcab shortbed (sold, sorry old friend) 2005 GMC 2500HD shortcrew Duramax 2006 K1500 RCSB and a couple other projects/parts |
09-24-2007, 12:38 PM | #19 |
At a car show, saw a polished stainless floor and then chrome wood bed hold down strips were applied..... looked very nice.... depending on the intended use, aluminum could also be used with the chrome wood hold downs or some other type metal strips, chrome, polished alum. or stainless. I have a short step which needs a new bed and I think at this point some type of metal bed with metal strip hold downs is what I'm planning.
71 GMC 1/2 ton 4x4, 350, 350th 67 chev short step, 396, 350th 41 chev flatbed, custom bed, frame & suspension, 350, 350th |
