Old 09-16-2007, 02:31 PM   #1
vtblazer
vtblazer's Avatar
Rear Axle Line Lock
Yep, that's right.
Installed line lock on the REAR axle.
Here's why:
It's all about doing front digs.
A right turn would go like this.
Kick out rear axle (doubler w/triple sticks)
Depress brake, depress line lock button to the inner tire (two separate buttons)
Release brake and power the front axle with the go pedal
Power through the turn and when straightened out, release the line lock button and go.
I didn't like having to overpower the brakes during the digs and figured if there was a way to only lock the inner tire, turning radius could be thighter.
So here's a couple pics of the install. (not 100% complete yet)
Momemtary contact swithes in console lid
Made a bracket to hold the solenoids
vtblazer is offline   Reply With Quote
Old 09-16-2007, 02:37 PM   #2
EFI70Blazer
Active Member
EFI70Blazer's Avatar
Re: Rear Axle Line Lock
Very cool. Seem like it would also work well when side hilling in the snow.
Mike T.
Oregon
70 GMC Jimmy 4x4
70 Camaro LS1 plans in the works
71 RS/SS Camaro numbers matching
86 Chevy Silverado SWB 4x4 (454 merlin heads, 3/4 running gear upgrade, Detroit lockers front and rear)
EFI70Blazer is offline   Reply With Quote
Old 09-16-2007, 08:05 PM   #3
pumpkin
pumpkin's Avatar
I'm guessing that your open in the rear?
pumpkin is offline   Reply With Quote
Old 09-16-2007, 11:40 PM   #4
bigtruck81
i would guess that if he's worried about doing front digs, its locked in the rear. but, kicking the power out to the rear axle, even a locked axle will act as if its open.
bigtruck81 is offline   Reply With Quote
Old 09-17-2007, 01:41 AM   #5
earl87gta
earl87gta's Avatar
Thats cool when are you going to go test it out?
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 09-17-2007, 01:47 AM   #6
EFI70Blazer
Active Member
Not sure it would matter since the rear is disengaged anyway. You would only be putting power to the front alowing the rear to pivot on the locked tire.
Mike T.
Oregon
70 GMC Jimmy 4x4
Old 09-17-2007, 07:00 AM   #7
vtblazer
vtblazer's Avatar
Heading to Rausch Creek again on the 20th.
To answer the 'locked' question, yes it's got a Detroit and yes by what I can find out about the Detroit, it will free up the opposing axle during this maneuver.
Old 09-17-2007, 07:15 AM   #8
jaros44sr
jaros44sr's Avatar
Nice work, soooo did you buy two line lock kits? I was going to hook up two separate e-brake handles to accomplish this, but your idea seems simplr. Maybe I'll see you at Rausch...J.
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 09-17-2007, 07:48 AM   #9
vtblazer
vtblazer's Avatar
No, not two kits just two solenoids.
The rest of the parts are just store bought to comply with my idea of how and where thing's should be installed and functioning.
You think you might make Rausch?
As of right now, I've got an open seat.
Old 09-17-2007, 03:09 PM   #10
jaros44sr
jaros44sr's Avatar
Hold it for me, give me 8 hrs. pls to figure it out. J.
SAFETY FIRST
AS usual, off topic
Jim
Old 09-17-2007, 03:52 PM   #11
bigtruck81
works very much the same as a trick brake on a sand rail, in fact, that's what most comp crawlers use.
Old 09-17-2007, 04:41 PM   #12
vtblazer
vtblazer's Avatar
Thought they were running split pedals.
Pic of em plumbed and wired up.
Reused the existing tubing running to the calipers, doesn't look the best but it's one less connection to have to break.
Jim, not a problem.
Old 09-24-2007, 06:47 PM   #13
vtblazer
vtblazer's Avatar
Update post trial run @ Rausch:
Works awesome!
