Old 09-24-2007, 06:04 PM   #1
dilling
running fuel injection ,where did you put computer
Where did you mount the computer
dilling is offline   Reply With Quote
Old 09-24-2007, 07:45 PM   #2
jkade
jkade's Avatar
Re: running fuel injection ,where did you put computer
Took glove box out and mounted it on the firewall.
jkade is offline   Reply With Quote
Old 09-24-2007, 10:29 PM   #3
billyjo
Junior Member
billyjo's Avatar
Same with mine, put it into the glove box.
1972 K/5 4x4, Radixed LS1 6.0, 428HP/445TQ, Lingenfelter GT2-3 cam, WCCH 90mm J-Tube, LS2 90mm TB, Stainless Works Headers, NV4500, 4.56 gears, Detroit Lockers, 14 bolt FF, Dana 60, 4 wheel disk Hydro Brakes, dual electric fans, Autometer guages, 4" lift, Zero Rates, Weld Evo Velocity XT8 wheels, 35x12.5x17 Super Swamper SSR's.....
http://s72.photobucket.com/albums/i1...tos/?start=all
billyjo is offline   Reply With Quote
Old 09-25-2007, 12:58 AM   #4
Deuce
Deuce's Avatar
Used the extended Painless harness and mounted it under the drivers seat.
I know what your thinking.......I have ESPN.
Sometimes it's easier to do things the hard way.
Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!!
Deuce is offline   Reply With Quote
Old 09-25-2007, 01:15 AM   #5
combustion
as far away from heat as possible id asume. on my sand rail its under my seat.
If it`s 3.73 ratio you will spint the wheel 100 times to the driveshaft`s 373 times.Or,if you`re lazy,you could just spin the wheel once and the driveshaft will spin 3.73 times.Or, 3 and 3/4 turns.And if you`re real lazy,I can sell you a tab for whatever ratio you want.
Or,you could read all the suggestions and try those.It`s been well explained,I think,already.
combustion is offline   Reply With Quote
Old 09-25-2007, 08:50 AM   #6
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
See the 3 screws on the flat part of the glovebox liner,it's mounted on the backside of it(wire hanging down had not been connected up yet.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 09-25-2007, 12:31 PM   #7
Kid
Kid's Avatar
Put mine under seat too, Speartech made my harness to length needed
Kid is offline   Reply With Quote
Old 09-25-2007, 02:21 PM   #8
Custom 68
Custom 68's Avatar
same here but under the passenger seat...
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 09-25-2007, 02:30 PM   #9
Ackattack
Ackattack's Avatar
In my gmc, it is located under the custom center console.
In the 68 chevy, I will mount it under the hood. The GenIII motors can have the computer mounted under the hood....that's where they're at from the factory.
Ackattack is offline   Reply With Quote
Old 09-25-2007, 04:47 PM   #10
bodydropped68
bodydropped68's Avatar
i mounted mine on the passanger side under the bench seat along with the spark control module,fuel pump & run relays and fuses with the long painless harness.that was 58,000 miles ago without any problems.
bodydropped68 is offline   Reply With Quote
Old 09-25-2007, 06:18 PM   #11
bigo181979
Junior Member
bigo181979's Avatar
Where did you run the wires through, fire wall or other and how big of a hole did you have to cut to get the big plug for the computer through? Got to see what others have done so I know what to do when I get to mine.
bigo181979 is offline   Reply With Quote
Old 09-25-2007, 08:20 PM   #12
clay68c10
clay68c10's Avatar
Mine's under the left side of the dash. I used the stock 89 thru-firewall square plastic thing from the donor truck to run the wiring inside.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 09-25-2007, 08:55 PM   #13
71swb4x4
71swb4x4's Avatar
I used the stock wiring harness and mounted it under my middle seat.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
