Old 12-30-2002, 01:24 PM   #1
sub4rvr
sub4rvr's Avatar
Temp gauge questions
I can't get my temp gauge to work. Is there some way to test the gauge? I've seen in the catalogs that there is an temp gauge resistor. I'm assuming that is mounted to the rear of the gauge. I've used two different sending units. Is it ok to use thread tape on the units, or does it need to be pipe dope. And, is the temp gauge wire to the sending unit green? I can't remember if the gauge worked with the old motor because I only started it a couple of times.
72 C10 Suburban
90 S10
57 F100 (2)
67 Mustang (2)
69 Torino GT
00 Mustang GT Conv.
sub4rvr is offline   Reply With Quote
Old 12-30-2002, 08:39 PM   #2
john
member #16
john's Avatar
Yes temp ga. wire is green. To check the guage you can turn ign. on and ground sensor wire, if the guage is working it will peg to the hot side. Also make sure your wire has continuity to ga.
john is offline   Reply With Quote
