09-28-2007, 10:01 AM | #1 |
hardware question for suspension stuff
This is kind of a weird question:
I've been using grade 8 hardware for my suspension from Tractor Supply - the gold colored stuff. My question is where do I get hardware that is silver in color? Is the grade 5 good enough or is there silver colored grade 8? |
09-28-2007, 11:32 AM | #2 |
Re: hardware question for suspension stuff
'Gold' = yellow zinc plating
'Silver' = bright zinc plating The only place I know to get bright zinc GRADE 8 is from a bolt supply house. For the high-end budget/build, stainless steel GRADE 8 hardware is available too.
09-28-2007, 01:28 PM | #4 |
I wouldn't use grade 5 on any of the chassis stuff cheap insurance
1968 Short Fleet 350/700r4 http://67-72chevytrucks.com/vboard/s...d.php?t=249435 1997 Bagged XtdCab Vortec350/4L60e http://67-72chevytrucks.com/vboard/s...44#post2286144 1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver" 1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap |
